Oil Transfer Pump
Old Feb 26, 2026 | 09:27 AM
SMarquez's Avatar
SMarquez
Oil Transfer Pump
I'm getting ready to service the diffs and transfer case on my 22 F250. I thought of the Valvoline squeeze bags but it's nearly twice as much as a 1 gallon jug. What pumps have you guys tried to do this service.
Thanks.
Steve
Old Feb 26, 2026 | 10:08 AM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
When I did my trans service, I bought a 2-gallon garden sprayer, the kind you pump up, and took the sprayer nozzle off the end of the wand, and used that.
Works great, if a little slow.
Lots cheaper than the more professional pump that a shop tech might use.
Old Feb 26, 2026 | 10:09 AM
Jay870's Avatar
Jay870
I used squeeze bags (Amsoil) when I did the diffs but used a Motive 1745 for the transmission and no reason it wouldn't work for gear oil.
https://www.motiveproducts.com/produ...nt=10120047301
I'd put a better ball valve on it if I were using it a ton but it is otherwise well made.
Old Feb 26, 2026 | 10:14 AM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
This is the one I use for a pump.
https://www.homedepot.com/p/HDX-2-Ga...766539#overlay
18 bucks compared to 103 for the motive and it works exactly the same way, just no gauge on it.
Old Feb 26, 2026 | 11:15 AM
Turbo Dog's Avatar
Turbo Dog
Interesting, do you take the tip off or the whole handle off?
Old Feb 26, 2026 | 11:22 AM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Just the tip that makes it spray a mist, then you still have the trigger on the wand to control the flow.
Old Feb 26, 2026 | 02:40 PM
SMarquez's Avatar
SMarquez
Being a cheap bass turd, I guess it's off to Homey Depot.
Old Feb 26, 2026 | 03:24 PM
augam's Avatar
augam
I have been using these $10 sprayers for decades while refilling the lower end on my outboard engines. Works great.
Old Feb 27, 2026 | 04:46 AM
Smokeatrr's Avatar
Smokeatrr
I kept one squeeze bags from previous fluid replacement and just keep refilling it.
Old Feb 27, 2026 | 07:56 AM
rufushusky's Avatar
rufushusky
Don't want to give this a whirl?
Personally, I have had good luck with the little hand pumps:
https://www.harborfreight.com/gear-o..._source=google
Old Feb 27, 2026 | 08:53 AM
speakerfritz's Avatar
speakerfritz
I have a 1/2 clear hose glued to a standard gear oil cap with the cap tip cut off to 3/8 hole. i put the tube in the gear box hole and hang the gear oil bottle upside down and squeeze and release repeat until the gear oil is bottle is empty.
I used to try various pump schemes by they all leak as you pump and it creares more mess than anything else.
Old Feb 27, 2026 | 08:25 PM
Turbo Dog's Avatar
Turbo Dog
Sounds like a good easy idea...I need to top off a manual transmission soon.
02sd
Sep 14, 2018 10:52 AM
Jarkill
Jan 12, 2017 12:52 PM
kona56
Sep 9, 2009 07:08 PM
MER
Offroad & 4x4
13
Feb 21, 2008 08:11 PM
