1987 4.9L throttle body set screw
Old Feb 25, 2026 | 01:56 PM
DillonShrader's Avatar
DillonShrader
4th Gear
I bought the truck and the idle sets around 900-1200 and I found out my set screw is missing from my throttle body. Does anyone know what size they are or where I could one?
Old Feb 25, 2026 | 02:02 PM
90project5.0's Avatar
90project5.0
Junkyard is the easiest place. As for buying one, you have a junk drawer with a bunch of random screws? I don’t know the thread pitch, but it’s fine thread. It idles around 1200 with the screw out? That’s a problem to deal with as well.
Old Feb 25, 2026 | 02:10 PM
DillonShrader
4th Gear
Yes there no set screw in it at all. The Idle air control sensor is new and the Throttle position sensor It also new throttle cable is new and has the ERG delete on it. I cant set the TPS right without the set screw I believe.
Old Feb 25, 2026 | 02:23 PM
90project5.0
That is correct. Once you get the screw, unplug the IAC and get it to idle at 550 rpm with screw. Plug IAC back in. Turn truck off and set tps signal to around .9v closed. You have a vacuum leak somewhere.
Old Feb 25, 2026 | 02:28 PM
DillonShrader
4th Gear
Okay thank you. That helps a lot. I have one vacuum leak and need to find the others. I would like to get it running to get the best mpg I can.
Old Feb 25, 2026 | 03:10 PM
90project5.0
5mm silicone vacuum hose, 20 ft roll on Amazon and an assortment of vacuum tees can redo all of it. $30-40 if I remember!
AlewisIII
Jan 9, 2022 03:25 PM
john-9
Aug 1, 2021 10:49 AM
Jrock909
Apr 23, 2007 08:20 AM
wiggles
1997 - 2003 F150
Oct 28, 2003 02:22 PM
