Throttle body.
Old Jan 9, 2022 | 02:51 PM
AlewisIII's Avatar
AlewisIII
Throttle body.
When you replace a mechanical throttle body how do you set the stop screw and IAC on a 94 f15.0 ?
Old Jan 9, 2022 | 03:25 PM
Conanski's Avatar
Conanski
There is nothing to set really, the stop screw should already be set to just stop the throttle blades from binding in tbe bores, and with the engine running and IAC disconnected the motor should be right at the point of stalling. When the IAC is connected the motor should settle into a 650-700rpm warm idle.
mayerst
Jan 9, 2022 07:10 PM
doctisdall
Jan 9, 2022 06:08 PM
adam.hilberath
Jan 13, 2013 03:37 PM
wiggles
1997 - 2003 F150
Oct 28, 2003 02:22 PM
