throttle body
Old Aug 1, 2021 | 04:48 AM
john-9's Avatar
john-9
throttle body
have a 1994 f150 5.8 litre engine -- - i think one of the previous owners may have turned the throttle plate stop screw to compensate for an idle problem as the throttle plates seem to be open too much -- so would anyone know what the correct position of the throttle plate stop screw should be as set from the factory on the throttle body -- just want to get back to the factory setting to try and eliminate an off idle stumble and erratic idle ,,,,,, thanks in advance
Old Aug 1, 2021 | 08:16 AM
My4Fordtrucks's Avatar
My4Fordtrucks
I would follow the BBK instructions starting at step 7.
Old Aug 1, 2021 | 08:54 AM
Conanski's Avatar
Conanski
All you need to do is prevent the throttle blades from fully closing and getting stuck in the bores, the voltage at the TPS should be in the range of 0.6-0.99v when that is done.
Old Aug 1, 2021 | 10:46 AM
jtab's Avatar
jtab
I heard to disconnect iac and adjust stop screw until the engine just barely runs. That way you're not stranded if the iac fails, but the iac an control idle if it's working.
Old Aug 1, 2021 | 10:49 AM
Conanski's Avatar
Conanski
Yes the IAC does control idle speed normally so the above is a good method.
rct2000
Apr 29, 2020 07:30 PM
Jrock909
Apr 23, 2007 08:20 AM
whalerron
Modular V8 (4.6L, 5.4L)
Jul 18, 2006 10:01 AM
puck1263
Nov 1, 2005 10:04 AM
gdoggy
1983 - 2012 Ranger & B-Series
Jun 19, 2003 03:15 PM
