Anyone install Diode Dynamic's C2 2.0 w/ Backlight as your fog lights?
Old Feb 24, 2026 | 06:47 PM
ds53652's Avatar
ds53652
Has anyone installed Diode Dynamic's C2 2.0 w/ Backlight as your fog lights? If so, how'd you wire up the Backlight portion?
For those unfamiliar with Diode Dynamic's C2 2.0 pods, the pods have a Main Beam (white) and a built-in Backlight that can be amber (for front facing applications) or red (for rear facing applications). They operate independently, but the Main Beam always automatically takes priority over the Backlight. Where I live, there's really no need for me to run with my fog lights on all of the time, so my desire/goal is to have the Backlights come on automatically with the truck's parking lights (in other words, when the headlights and/or parking lights are on) and act as basically an additional set of amber parking/running lights at night. And then when I manually turn on the fog lights or when the turn light mode for the fog lights activate, the Main Beams will override the Backlights. Could it be as easy as tapping into the front parking lamp wire(s) for the Backlights portion?
Old Feb 24, 2026 | 08:16 PM
TheCyborgSlayer's Avatar
TheCyborgSlayer
I was looking at these when they offered the five light row that installed in the air dam. You’d wire the backlight to an upfitter switch and essentially just leave it on all the time if I remember correctly.
Old Feb 24, 2026 | 08:42 PM
ds53652's Avatar
ds53652
Yep, I hear ya. That's my plan B. Ideally...I only want them to come on at night when the auto headlights come on or when I manually turn on the headlights/parking lights. That's why I'm trying to figure out if it will work with just tying them into the parking lights. And if so, what's the best way to do so?
Old Feb 24, 2026 | 09:52 PM
Don Ridley's Avatar
Don Ridley
I tapped into the parking lamp and used a relay. Since the current draw is low you should be able to power the backlight directly from the parking lamp if your parking lamps are old school incandescent. If they are an LED assembly they will be powered by PWM and this may be a problem for the Diode Dynamics.
I'm using a yellow fog as DRL for normal driving and fog when needed. This requires a switch and relay so the DRL turn off with headlights, and turn on with headlights when in fog mode.
Old Feb 25, 2026 | 04:39 AM
Poncho450's Avatar
Poncho450
Probably doesn't apply to your situation but if you have factory fogs they can be turned on for DRL with FORScan. I put yellow Lamin-x film on my fogs and have them as DRL. Nice contrast with the white C ring on the headlights.
McConnell 91
Aftermarket Products
Mar 19, 2023 04:30 PM
stansrubyred2013
General Automotive Discussion
Jul 31, 2017 12:32 AM
cecilt
Feb 3, 2011 10:06 AM
mtflat
2004 - 2008 F150
Feb 7, 2006 11:00 AM
sic inside
Apr 27, 2005 01:59 PM
