driving/fog light ??
Old Feb 5, 2006 | 11:23 PM
mtflat's Avatar
mtflat
For you guys running the new trucks I have a question - are your fog/driving lights switched separately from the headlights? In other words, do your driving lights have to be on when the headlights are on or is it driver's choice?
Thanks
Tim
Old Feb 5, 2006 | 11:51 PM
ReForder's Avatar
ReForder
I can turn the fog lights on as long as the parking lights are on. It's not possible, in stock configuration, to turn on the fog lights by themselves.
Old Feb 6, 2006 | 11:55 AM
mtflat's Avatar
mtflat
Thanks for the reply! I've wondered about the drivers I've met running with the fog lights on when the weather isn't snowy/foggy/rainy. Sometimes worse than bright beams for oncoming traffic.
Those drivers usually get a dose of my brights and I've started to wonder if it's stupidity on their part or a mfg design screwup. On my Dodge they're separate switches and I figured Ford did the same.
Now that I know they don't have to run with the lights on, it back to "educating the ignorant".
Old Feb 6, 2006 | 11:58 AM
Hausladen's Avatar
Hausladen
The fog lights on the new f150's are not that bad, i can stand them being on all the time, but man some of those aftermarket fog lights are rediculous.
Old Feb 7, 2006 | 11:00 AM
Dazz's Avatar
Dazz
What I have found to be most unsafe and very obnoxious is those who put OEM Starlights in either the driving lights or fogs. When the owner installs these OEM Starlights they often do not know how to adjust them so that oncoming drivers will not be blinded by the low beam Starlights. I have found this especially true with those who do a lift kit and also Starlights. If the owners of Lifts and Starlights thinks it gathers them more attention, they are correct.
What is most unsafe is when I have flicked my high beams on to "ask" Starlights to lower what I think is oncoming high beams, in turn, the Starlights that were maladjusted low beams are flicked to high beam and the high beam just blinds the path in front of me......Rude and unsafe way to garner attention.
