fog lights problem
Old Apr 26, 2005 | 04:53 PM
sic inside's Avatar
sic inside
fog lights problem
on my 01 the factory fog lights don't turn on...i've seen them on with other superduties...so whats the secret...they don't come on with the regular lights or high beams...what do i need to do to fix the problem...thanx..
Old Apr 26, 2005 | 06:33 PM
01psd's Avatar
01psd
sic inside, fog lights will not operate when bright lights are on. look on your light switch. panel you will see on right side a symbel for your fog lights turn **** to the right and pull out on **** then your fog lights should come on. there is another thing you can do,and thats install what they call a brite box that gets wired in to your lights then you can run fog lights when ever you want. go to www.diesel site and you see what Im talking about. 01psd
Old Apr 26, 2005 | 07:28 PM
sic inside's Avatar
sic inside
hey man thanx alot...ya know its the simple things...
Old Apr 27, 2005 | 01:59 PM
FLASH 13's Avatar
FLASH 13
my truck does not have factory fog lights but it looks like there is wires for it can anyone confirm
