retractable side and rear steps
Has anyone actually ordered the side and rear retractable steps either from the factory? If so, couple of questions.
1) are they placed on both sides? - EDIT, yep, the factory option has both sides..
2) how useful are they? I admit that 10 years ago, I would not need help getting up onto the side steps and corner step cutouts located on the bed and the bumper, but getting my leg up there and then hoisting myself up there today just doesn't seem as easy as it used to be. Especially in winter. I am looking for something to give me a leg up so I can clean off the top of my cap after a snow fall. Since I am getting a long bed this time, the extra 18 inches means I will need something more than opening the door and brushing off the cap, which is what I use today. Brush pretty much maxes out just short of the back on my short bed.
3) how well do they hold up?
1) are they placed on both sides? For example, if I ordered the retractable side step, is it located on both the driver and passenger side? Same would apply to the rear step. Reason I ask is that it appears that ordering on a new vehicle might be cheaper than getting two later
2. I don't use them much but I do use them on uneven ground, when the ground is sloping down from the truck position. In the desert with the uneven ground they help.
3. They're made by AMP and were marketed for years as BED STEP 2.
That being said, I ordered the tailgate step on my long bed build, but held off on the additional side steps to see if I indeed need them later (I am not running a bed cap though). From what I saw I can get them from AMP and it is not a difficult install if the side step-up proves to be a problem for me. They ain't cheap for what you get.
I am in the middle of trying to add them to my order, but if not, at least I know I can get them (and cheaper too) direct from AMP...
Just so you know.. The front corner ones don't look great! But they help.
[img alt="75422-01A Driver side
75423-01A Passenger side"]https://cimg7.ibsrv.net/gimg/www.ford-trucks.com-vbulletin/2000x826/capture1_d5a6642746a12eae7134f60c87d52a6ffedfd6b6. jpg[/img]
75422-01A Driver side 75423-01A Passenger side
75423-01A Passenger side"]https://cimg8.ibsrv.net/gimg/www.ford-trucks.com-vbulletin/2000x651/capture2_6e554261b4bece5e22ce1a63e96da3a4eac638aa. jpg[/img]
If the images don't appear, you can see them here: https://imgur.com/a/u2PDwWX
That is an option I wish I would have "checked" on my build.
