VSS vs OSS
One question I have right off the bat is how does the 4R70W transmission's speed sensor (OSS) fit into this mix, if at all?
The truck is a 1995 F150 5.0 MAF w/4R70W rear wheel drive. California edition Eddie Bauer.
If you care to know what the OSS is used for:
On the 452, I had read a dozen threads here and elsewhere then did my hybridized diagnostics. 1200 ohms across rear axle VSS. (some say 1000-2500 is correct, others say 190-250). Wiring had good continuity and no shorts in between RABS test connector and VSS. Went straight to the PSOM. It has a shorted diode and an overheated MOV. I'll make those repairs and then see if more diagnostics are in order.
Truck has had wonky transmission shifts since I got it. Didn't give it much thought since the truck obviously did not run at all well. But now, with the running issues solved, and with the truck running great, it became obvious that the shifting was not right. Then, while driving down the dual lane, I tried the cruise control. It engaged for about three seconds then disengaged. I got a flashing OD OFF (which had happened before) along with an audible alarm beeping with the OD OFF light. Then the truck stayed running but lost nearly all power. I don't remember what I did to reel it back in but was able to get the truck home under seemingly normal power.
Then we got hammered with fifteen inches of snow on January 25. My garage had to be made available for the vehicles I drive. I'm just now getting back to the project.
One section I refer to all the time is part of a TSB Ford issued years ago regarding speedometer pointer waver
J3 CHECK SPEED INPUT SIGNAL
Connect Rotunda 88 Digital Multimeter 105-00053 or equivalent to Pin 4 (speed ) and Pin 5 (speed -). If available, a frequency counter may be connected to Pin 4 (speed in ) and Pin 5 (speed in -). CAUTION: Make sure multimeter is in the voltage function and not in the resistance function to avoid damage to multimeter. NOTE: Only wiring harness end of connector is to be probed.
Does the displayed frequency of the signal increase smoothly and continuously from 0 to approximately 667 Hz at approximately 48 km/h (30 mph)? OR does the voltage increase smoothly and continuously from 0 to approximately 3.5 volts as vehicle speed increases from 0 to approximately 48 km/h (30 mph)?
Yes REPLACE instrument cluster . SERVICE wiring.
No CHECK for open wiring. If no problems are found, REFER to Section 06-09A or Section 06-09B .
As a quick check you can snag the raw VSS signal at the RABS test connector under the hood instead of the connector at the PSOM. If the signal is good there, then tear into the dash.
My 1995 Ford PCED manual lists the VSS resistance as between 1300 and 1550 ohms (disconnected from the circuit).
VSS circuit diagram for reference:
I struck out 100% at the electronics parts store. So, more surfing and I found a parts list on a good YouTube video. Ordered and awaiting delivery.
Parts list for common PSOM repair: Parts were $4.50US. Shipping, tax and tariff was an additional $11.50
MOV= Mouser# 871-B72214s1140K501
Mfr# B72214s1140K501
Capacitor= Mouser# 667-ECE-A1VKS4R7I *note last character is an I
Mfr# ECE-A1VKS4R7I
Capacitor= Mouser# 667-EEU-FC1V101
Mfr# EEU-FC1V101
Rectifier= Mouser# 625-GL41G-E3
Mfr# GL41G-E3/96
I just couldn't get to any OSSs on several of the transmission Code U vehicles (earlier than 2001) One I could get to was stuck fast and was just not going to come out with tools on hand and without damage (as in, probably snap in two)
Questions about OSS in transmission. Do the 4R70W and E4OD use the same sensor? Parts catalogs tend to say yes. What ohms should a good OSS be?
E4OD does not have an OSS. My Ford Service Manual states the 4R70W OSS resistance should be between 450 and 750 ohms.
One juror in my mind is not yet convinced but is coming around.
If the 452 code issues are fixed, well, that's great. After driving the truck and then moving it over to its designated parking spot, I couldn't help but notice a 6" diameter spot of antifreeze residue where it's been sitting for about a week.
I do believe I need to pull the cluster back out. These four screws go somewhere
A local guy is parting out a '95 manual transmission truck. I can see in the dash photo that the unit has both the Select and Reset buttons.
