installed new gauge cluster
Old Feb 24, 2026 | 07:35 PM
DAM650's Avatar
DAM650
4wd Low
89 f150 lariat XLT 4x4 4.9 5 speed
missing the voltage, and the speedo
have not got a clue how to start fixing the voltage
have verified that the speedo cable is good, the gear sensor that goes into the transfer looks good, and the speedo will spin if you turn it manually with the end of it that goes into the transfer case. but no go when i plug it in to the transfer case.
can y'all give me some starting points for the voltage gauge and speedo issues.
thank you
Old Feb 25, 2026 | 08:20 AM
manicmechanic007's Avatar
manicmechanic007
The drive gear inside the transfer case can wear down or pop out of position
Stick your finger in the VSS hole and "feel" the drive gear
It should be nice and flat with no convex surface
It should be straight in there, not off to one side
When you spin the cable with your fingers, the speedo needle moves, right?
Old Feb 25, 2026 | 05:59 PM
DAM650's Avatar
DAM650
4wd Low
Yes it does turn when doing manually.
Searched for a while trying to find the transfer case gear.
Any sources?
Old Feb 25, 2026 | 08:41 PM
manicmechanic007
Get the Ford part number from a Ford dealer then search Ebay if they say it's obsolete
What color is it, how many teeth is what you need to know
Old Feb 26, 2026 | 06:53 PM
whisler's Avatar
whisler
Check the nut on the rear output yoke on the transfer case. If loose, it let's the speedometer drive gear slide out of position.
Old Feb 27, 2026 | 10:40 AM
Conanski's Avatar
Conanski
What year of truck did the replacement cluster come from?
The individual gauges unplug from the front if you remove the clear plastic lens, the contacts they plug into can corrode and cause issues.
Walker Powell
16
Dec 15, 2023 10:43 AM
Swoop03
Oct 28, 2013 07:05 PM
86f250XLT-4x4
Dec 16, 2011 12:20 AM
wreckinball
Mar 8, 2011 02:24 PM
