Sponsored by: Real Truck
Where does this go??!!
Old Dec 16, 2002 | 09:23 AM
FortyFords's Avatar
FortyFords
Ceejay !
I chkd this am there is a black piece of plastic attached to the front
seat cover material that folds under and is used to hold the seatcover
to the frame of the seat.But mine is sewn and has a glue substance on it
that keeps it attached to the material.Its a little tricky to reattach ,but if the old man can do it !!*****
Hope this helps!
Rich
02 F250 4x4 SC 5.4v8 6spd 3.73ls Trueblue/Silver and Chrome Nerfs
"All Levers"
Old Dec 16, 2002 | 09:43 AM
CBSuperduty's Avatar
CBSuperduty
I found the peice laying on my floor about 1 week after I brought her home. I just keep it under my seat in case I figure out what it is for.
Old Dec 16, 2002 | 09:48 AM
CBSuperduty
Old Dec 16, 2002 | 09:52 AM
79CEEJAY's Avatar
79CEEJAY
>Ceejay !
>the front
>seatcover
>substance on it
>Hope this helps!
Thanks for checking, Rich. I saw where it attatches the seat cover to the seat frame. It did come lose about two weeks ago and I muscled it back in place. However the piece that I am questioning is about that same length, but it is not hooked to anything at all. I'm gona check the passenger seat to see if I can find it. Thanks.
>Rich
>Nerfs
>"All Levers"
>No mods needed its "Kuel-E-Nough for Me!"
Old Dec 16, 2002 | 09:54 AM
79CEEJAY's Avatar
79CEEJAY
CBSUPERDUTY, it appears that this piece goes to nothing. It seems that they fall out often. I'm on a mission now!!!!!!!
:-X12
Old Dec 16, 2002 | 10:50 AM
79CEEJAY's Avatar
79CEEJAY
I FOUND IT!
For all who's interested, it goes on the inside...toward console..where the seat frame meets the jute/springs. It is the part of the seat frame they lay on. This piece goes between the seat metal lip where the jute/springs lay. It probably does not matter if it is there or not, but since it was there from the factory, I went ahead and put it back in. I think it is used the seperate the spring wires from the metal frame to prevent chafing. Well that's it...if a small piece of stripping falls from under yer seat, that's where it goes.....although you have to be a contortionist to put it back with the seat in, but it CAN be done.
Gary Lewis
29
Nov 15, 2011 06:13 PM
jyount
1997 - 2003 F150
Aug 11, 2011 11:14 PM
maticuno
Escape & Escape Hybrid
Jul 26, 2011 06:13 PM
matt2491
45
Mar 13, 2008 04:08 PM
sigtauenus
Aug 12, 2003 11:38 PM
