Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Deteriorating Weatherstripping
Old Jul 25, 2011 | 11:52 AM
maticuno's Avatar
maticuno
So my wife tells me that there is a sticky goo all over the bottom of the driver's door on her '07 FEH. I go to investigate and find a clear, sticky, odorless substance all over the bottom edge where the weatherstripping meets the door. The weatherstripping has one noticeable hole and it looks like the rest is deteriorating. It looks like the clear goop is coming out of the weatherstripping. Any ideas? The stuff is very difficult to remove, as you can tell by the lint left over from the rag I used to try to wipe it off. It's only the driver's door doing this, all other weatherstripping looks great.
Old Jul 25, 2011 | 12:02 PM
BlueOvalDude's Avatar
BlueOvalDude
maticuno,
Don't quote me but I believe that Ford has released a Technical Service Bulletin regarding the weatherstripping on later model Escapes. It's TSB #09-20-15, if I recall correctly. I would call the local Ford dealership and inquire about more details regarding this TSB.
Hopefully the dealer will do the honourable thing and replace the problematic stripping for free. If not then they will charge about $95 for the replacement weatherstripping
Regardless, I wish you the best of luck resolving this sticky situation!
Old Jul 26, 2011 | 06:13 PM
maticuno's Avatar
maticuno
Thanks for the info. With 114,000 miles there is no way my local dealer will honor the TSB. I'll just have to shell out the $97 for the stripping.
Rockinfigs
Nov 24, 2017 10:15 PM
mastiff23
Apr 22, 2017 06:54 AM
tj90
Nov 17, 2016 05:51 AM
scooterspal
Mar 20, 2012 09:47 PM
shooer
Apr 10, 2008 06:17 PM
