Sponsored by: Real Truck
Third brake light camera
Old Feb 18, 2026 | 01:29 PM
CitrusDragon's Avatar
CitrusDragon
Question Third brake light camera
I am probably to to get yelled at for asking this but I did try to use the search first I promise.
I bought a third brake light camera cheap. I thought since I have my dash pulled down/apart to do the shift tube, have the cluster repaired, and replace the shift indicator. I might as well install the camera. I just need to wire it up. I plan to run the wires across the headliner. I just need to know what wire to tap for the trigger, I want to keep the wires in the cab if I can. Also if some one wants to be nice. Could you post a picture of where to find the wire?
Old Feb 18, 2026 | 01:38 PM
Blksmk80's Avatar
Blksmk80
Active Streak: 30 Days
Im going to guess you can run a switch to turn the camera on, or use the reverse lights as the trigger.
Im just guessing.
Old Feb 18, 2026 | 04:58 PM
CitrusDragon
Im just guessing.
I figured I could do that but I don't know which wire to tap into. I read something about a pk/bk wire but I can't find any pictures
BroncoRN
Nov 2, 2012 01:03 PM
Oldbirddog
2009 - 2014 F150
Sep 28, 2011 06:27 AM
ddavie
2004 - 2008 F150
Feb 15, 2008 09:56 PM
Clint40
Oct 11, 2007 11:35 AM
Casey245
Dec 25, 2004 07:23 PM
