Sponsored by: Real Truck
CCV replacement question
Old Feb 2, 2026 | 07:47 AM
smr camper's Avatar
smr camper
Going to replace the CCV and have a question.
I watched a video and the guy said something about the collar kit replacement might be an issue. I really didn't understand what he was saying as it was a quick comment
I did get the collar replaced, should there be any issues removing the CCV
Is this the correct part number. FC3Z-6A785-C
Any other tips will be appreciated
Thanks
Old Feb 3, 2026 | 09:47 AM
Overkill2's Avatar
Overkill2
Thanks
Could you post up the video? I did a S&S DPK kit on mine and had to disconnect the hose off the intake to pull the whole intake assembly out. I had to slide the "rubber" cover off that exposed the two tabs holding it on the intake. The two tabs I had to push up, held them up with two small screwdrivers and then remove the hose from the intake feed there. I reused my original CCV box but I do have an Improved Racing CCR catch can using Mishimoto adapters that are installed under the CCV box as I replaced the Mishimoto catch can that I installed. What is this collar kit you mentioned?
Does yours have a connector on it? My 16 does not. I'll wait for you to respond before I comment further.
Old Feb 4, 2026 | 12:48 PM
speakerfritz's Avatar
speakerfritz
when i removed the ccv on my 2019 I just twisted and pulled and it came out....no fiddling with tabs or peeling back plastic.
Old Feb 4, 2026 | 03:31 PM
smr camper's Avatar
smr camper
I'll try to find the video, I watched a few others that didn't mention the collar kit.
Old Feb 18, 2026 | 09:19 PM
smr camper's Avatar
smr camper
Changed it out the other day and had no issues getting it off and the new one back on the collar, probably easiest part of the project. Fortunately I had a friend help me out who understands mechanics a lot better than I do, so I also learned a few things.
Still can't find that original video....so we used a different one.
I also changed out the fuel filters.
the collar kit was a recall that was done on the truck I I think 2022
DuallyMike
6.4L Power Stroke Diesel
Jun 27, 2024 04:32 PM
2003 EXCURSION
Jun 7, 2022 03:34 PM
Dude-Ford
Sep 13, 2017 06:04 AM
90XLT_Silver_Bullet
Aerostar
Feb 29, 2004 02:45 PM
