No crank, no start, no PCM communication
Old Feb 18, 2026 | 06:41 PM
Cuthbert's Avatar
Cuthbert
4wd Low
Originally Posted by texastech_diesel
I'm in Ft Worth, if you were here I'd let you come grab a PCM out of my trucks but I can't get it down to you, sorry. There are a few shops that rebuild them, might be worth sending it out while you're hunting down wires.
Hey that would be nice lol but no worries. I got ahold of a mobile mechanic that might have one I can at least test on before making the commitment.
You are still greatly appreciated sir.
Old Feb 21, 2026 | 05:20 PM
BLADE35's Avatar
BLADE35
Originally Posted by Cuthbert
I’m getting power into the PCM as pins 86 and 30 of the PCM relay are showing 12V. But testing the voltage going out of the PCM at circuit 361 - PCM connector C1381a (left plug) at pins 34 and 46, I am only seein.
it’s got Whats it needs going to relay looks good so far
but what comes out that relay
Whats pin 85 and 87 show need to be 12 volt here
then passes thru fuse F2-22 it should be hot 12v thru fuse
At one point you mentions only 1.5v at fuse this important verify
Old Feb 21, 2026 | 05:37 PM
BLADE35's Avatar
BLADE35
Have you tested pcm plug end
pin 34 and 46 still no power
there was the diode
suppose you could jump wire with fuse 34 46 kinda worrisome doing that but
Old Feb 22, 2026 | 08:04 AM
drtech's Avatar
drtech
7th Gear
try a new Ficm relay, They can cause alot of issues if bad
Knote
Feb 3, 2022 10:12 PM
G mann
Feb 3, 2022 06:56 PM
CurtisW14
Apr 26, 2021 06:20 PM
beachcamperf250
Transit Connect
Sep 5, 2019 09:44 AM
JACKA$$
19
Apr 25, 2010 03:54 PM
