6.0 no crank
Old Jan 26, 2022 | 06:26 PM
G mann's Avatar
G mann
6.0 no crank
I have a2003 f250 no crank no start starter good move around relays seems fuel pump is not getting fuel to filter pump is new
Old Jan 26, 2022 | 08:19 PM
bismic's Avatar
bismic
You didn't say so, but I assume you checked all fuses? Especially fuse 22 in the fuse box below the dash on the driver's side.
When neither the starter relay activates nor the fuel pump relay activates, more than likely the PCM is not satisfied with something.
Do you have a good scan tool? Codes are your friend. Also, we need to know if a scan tool can communicate with the PCM through the DLC (Data Link Connector).
A couple of things to look at while we wait for codes:
Turn the key on, put it in reverse and have someone tell you if your reverse lights come on.
Lastly, look over the fan clutch connector (at the clutch) and the wiring harness - as far back to the PCM as you can get a good look at it.
You can start doing some electrical testing also, but the two items above are quick and easy. You can get to the electrical testing (verifying power to the relays) after looking at the above.
Edit - one other thing you can verify is that the inertia switch on the fuel system has not been activated.
Old Jan 27, 2022 | 10:12 AM
runthatjunk's Avatar
runthatjunk
Bismic, what are the reverse lights supposed to be telling us?
Old Jan 27, 2022 | 11:55 AM
bismic's Avatar
bismic
Functional reverse lights will show that the Transmission Range Sensor is functioning and that the 12V power to it is at least good enough for the TRS to work. One of the reasons that the PCM doesn't activate the grounds to the fuel pump and to the starter is if the 12V system is being pulled down by a short somewhere.
We know the issue isn't a TRS issue by itself - because the starter won't be activated by the PCM with a bad TRS, but the fuel pump will. The OP has an issue with both the starter and the fuel pump function.
Old Jan 27, 2022 | 09:16 PM
SRGN's Avatar
SRGN
Have you tried cranking in neutral, or just park?
Old Jan 27, 2022 | 09:21 PM
SRGN's Avatar
SRGN
Also, check fuse 31 and fuse 113 in the fuse panel under the dash.
Old Jan 27, 2022 | 09:31 PM
bismic's Avatar
bismic
Good to check those fuses, but his fuel pump does not turn on either. Could also be the integral fuel pump relay in the CJB, or a fuel pump fuse, or even wiring issues. We are starting to get into multiple failures that way. Might be possible. I like to investigate the single reason possibilities that fit the symptoms. Especially when it is easy to test.
I gave him the SIMPLEST start possible to get him involved in troubleshooting. Like so many others, we don't hear back right away (and sometimes not at all) for whatever reason. He hasn't been back since starting the thread.
"Stalled thread" without the OP ..........
Old Jan 27, 2022 | 09:35 PM
SRGN's Avatar
SRGN
Unfortunately, sometimes an OP never returns after getting it figured out. Hopefully we get some information, even if they got it fixed.
Old Jan 31, 2022 | 03:05 PM
G mann's Avatar
G mann
I have tested the fuses and relays not the reverse light I will tonight the starter is good I did try neutral with no luck the truck will not read or comuicate with the scanner ididnot check clutch I will tonight
Old Jan 31, 2022 | 03:08 PM
G mann's Avatar
G mann
I also replaced the pcm but only with the same result
Old Jan 31, 2022 | 03:11 PM
G mann's Avatar
G mann
also It took a few days for me to get this response
Old Jan 31, 2022 | 03:22 PM
bismic's Avatar
bismic
So standard transmission? I did not see that earlier. Still would like to see the reverse light operate.
Appreciate you checking back in.
Old Jan 31, 2022 | 03:24 PM
G mann's Avatar
G mann
I meant the fan clutch yes brake lights work it's an auto trans
Old Jan 31, 2022 | 03:31 PM
bismic's Avatar
bismic
Gotcha, sorry
Old Jan 31, 2022 | 03:36 PM
bismic's Avatar
bismic
You say you have verified the relay, but I am not sure how deep you went into that relay. Is it getting power to position 30 of the relay (from fuse 113)? This should be hot at all times.
Then, is the starter relay getting the ground applied by the PCM when you try to crank? I suspect it isn't.
The ground is applied at position 86 on the relay, or you can backprobe the PCM connector C1381a, pin #4 (Pink wire).
