AJ-V8 to ZF S5-47?
AJ-V8 to ZF S5-47?
Has anyone looked at using the AJ-V8 as an alternative to the 460? ...asking bc my 460 is on its last legs and I have a AJ-V8 that's needing a new home (400+hp, 400+ftlbs stock)
If so, has anyone found an adapter that'll take me from the AJ bell housing to the ZF S5 housing?
Oddball combo to consider I know, but when the engine is free...
Thanks!
C
Thanks!
C
The right generation Land Rover will be BMW electronics, and some generations of those are pretty easy to adapt
(I'm familiar with MS43, but MS45.1 and V70 and V80 are now pretty well opened up)
t
t
294 hp at 6,000 rpm with 303 lb⋅ft of torque at 4,100 rpm
Vs
245 Hp @ 4000 rpm400 ft/lb torque @ 2200 rpm
im not saying dont do it. But, if the truck is going to be worked like a 460 truck... you are missing at best 100 lb-ft of torque and the 100 less it does make is at twice the rpm of the 460.
Yeah it make 50 more hp... at 2000 rpm more than the 460...
Would it be a neat swap? Maybe.
Would it be practical? Probably not.
Vs
Planned on pulling the existing harness and stripping it down. ...again, free hardware...
Ah! Good to know! I haven't starting pulling electronics out yet... You have a website or some such that'll help me identify which system I have? Thanks!
Vs
Vs
Different vehicles got different electronics, and the best advise is usually on the vehicle- specific forums.
t
moneypit ford
Feb 5, 2023 11:46 AM
mudduck72
Sep 15, 2004 06:21 AM
flexybronc
May 22, 2004 09:18 PM
saddletramp
Apr 25, 2000 02:44 PM
