Sponsored by: Auxito
wheel stud size
Old Feb 13, 2026 | 02:04 AM
Michael Lizotte's Avatar
Michael Lizotte
wheel stud size
My haynes manual says there are 2 wheel stud sizes therefor 2 different torque specs. 12x1.75 or 14x1.50 is there a marking on the end of the studs to tell? thanks
Old Feb 13, 2026 | 07:13 AM
manicmechanic007's Avatar
manicmechanic007
Just take a 12mm wrench and a 14mm wrench to your studs
See which one fits
Sure, there are probably numbers you can research, but time is money
Good luck
The 12mm has a 3/4 socket that fits
The 14mm needs a 21mm socket
Old Feb 13, 2026 | 01:02 PM
Michael Lizotte
Thanks, mine needed a 21mm socket so I will need to use 150 ft lbs of torque.
Old Feb 13, 2026 | 01:17 PM
BareBonesXL's Avatar
BareBonesXL
I think that they changed to 14 mm in 2000.
Yep, 150 ft-lbs. That's a lot. Scary.
Old Feb 13, 2026 | 05:16 PM
Michael Lizotte
i hope i never get a flat. I will need to add a 2' extension pipe to the end of my breaker bar to get those off.
Old Feb 14, 2026 | 08:32 AM
Hit Man X's Avatar
Hit Man X
I bought a 1/2" breaker bar and socket from Harbor Freight to keep in the back of the truck for that reason.
Make sure you have spare tyre release crank rod too under the hood! Mine was MIA when I purchased this truck I am always perplexed when those vanish along with all floor mats
Old Feb 14, 2026 | 11:26 AM
Michael Lizotte
True, it did that me some time to figure out how to remove the old spare tire.
Old Feb 14, 2026 | 11:29 AM
Michael Lizotte
Thanks, maybe you should try to see if you can do it without a extension pipe, I could barely remove my 100 lugs on my car, it only had 100 ft.
Rangervx
2023+ Super Duty
Feb 15, 2025 02:56 PM
RTT
Mar 28, 2021 05:21 PM
BarryMc
May 8, 2008 01:25 AM
D8chumley
Jan 15, 2007 03:38 PM
Matt66
May 27, 2006 07:35 AM
