Alternator help
Old Feb 12, 2026 | 03:16 PM
Onyx812's Avatar
Onyx812
Alternator help
Hello friends I have a 82 f100 302 im trying to change the alternator but the bottom bolt is giving issues and how do I get the belt off thanks in advance.
Old Feb 12, 2026 | 05:22 PM
Franklin2's Avatar
Franklin2
You will have to cut the belt, and then take a hacksaw or sawzall and cut the alternator bolt. However you can get to it. Sorry, this is a Ford thing and is very common. The alternator bolt corrodes to the hole in the alternator. It is usually not possible, but if you can take the whole engine bracket off with the stuck alternator on it, you can take it to the workbench and try to get it out.
Just wait till one day when you have to change the waterpump. It can all happen again with the waterpump bolts, and you might have to get a new timing cover. They do sell them at the local stores.
Old Feb 12, 2026 | 05:29 PM
Olds64's Avatar
Olds64
MAW try a cheater bar and plenty of PB Blaster or Kroil before going to a hacksaw. Good luck!
Old Feb 12, 2026 | 07:25 PM
BigBlue2's Avatar
BigBlue2
Times two on the penetrant. PB or whatever you have. And if time permits apply two or more times per day. Vibration helps to work the penetrant into the threads. If you have an impact drill or drill with the hammer mode chuck up a socket and while applying penetrant vibrate it in with the impact or drill. Don't need to break it, just shake it...I have done that routine for a week and more but eventually you can often win with patience and persistence.
Old Feb 13, 2026 | 07:05 AM
Onyx812's Avatar
Onyx812
I bought a impact ratchet and gonna try that the alternator was changed towards the end if 2025 from what the kids said but I think the bad battery and the cold killed it so it should give it had a little give but the position of it makes it awkward to put some strength into but what about the belt I don't see a tensioner or its just hidden.
Old Feb 13, 2026 | 07:08 AM
FuzzFace2's Avatar
FuzzFace2
Someone just went through this https://www.ford-trucks.com/forums/1...lternator.html
Any way to get a propane torch in there to heat that bolt?
Not the end but the whole bolt from head to block?
Dave ----
Old Feb 13, 2026 | 11:23 AM
kr98664's Avatar
kr98664
If your arrangement is like my '84 351W, there is no separate tensioner. There's a long bolt at the top on which the alternator pivots. At the bottom, there's a short bolt with the head facing aft. This bolt passes through a slotted adjuster bracket. To find this bolt, you've got to feel for it by Braille from underneath. Loosen this short bolt and then you can move the whole alternator left and right to adjust belt tension.
Old Feb 13, 2026 | 11:59 AM
Max Capacity's Avatar
Max Capacity
Not sure if your 82 is the same, but here's that slotted piece.
Old Feb 13, 2026 | 12:13 PM
Onyx812's Avatar
Onyx812
im working on that bolt now but its being stubborn is it reverse cause this thing feels like it gets more loose when I crank it right instead of left im using pb blaster and a breaker bar
Old Feb 13, 2026 | 12:19 PM
Max Capacity
No it is a normal threaded bolt, not left hand threads.
Make sure to use anti-seize on the threads when going back together. Also on that long bolt too.
Here's an older picture, notice the old two votlage reg connector.
Old Feb 13, 2026 | 12:48 PM
Onyx812's Avatar
Onyx812
I got the alternator out but by just taking the lower bracket off the small bolt that goes in the alternator is spinning
tractorboy924
2009 - 2014 F150
Oct 16, 2017 10:39 AM
CPL. Chaz
Aug 27, 2013 01:46 PM
joes52f6
Nov 7, 2006 02:43 AM
smitty7
1983 - 2012 Ranger & B-Series
Oct 31, 2004 01:48 PM
jherman
Sep 18, 2002 05:35 PM
