Confirm My Fluids
Old Feb 9, 2026 | 07:02 PM
ruli00's Avatar
ruli00
Confirm My Fluids
75k and I want to change all the fluids. Did the trans about 10k miles ago so its fine. 2020 F250 4x4 SRW 6.7 with heavy duty payload package so it has the F350 rear end. This is what I found but can someone confirm I'm ordering the correct fluids and if the amount I'm ordering will cover?
Thanks everyone!
Power Steering Mercon LV - 1 gallon
Transfer Case Mercon LV - 1 gallon
Cooling Systems (both) Motorcraft VC-13 - 7 gallons of concentrated
Front Diff SAE 80w-90 - 3 quarts
Rear Diff m275 SAE 75w-140 - 5 quarts
Old Feb 10, 2026 | 02:25 PM
rufushusky's Avatar
rufushusky
Your transfer case won't take a whole gallon, two quarts is usually enough. Power steering will require pulling some hoses cause the reservoir has a mesh screen on it. 7 gallons is correct for concentrated coolant, that said IMHO zero need to change VC-13 coolant that early. It is a P-OAT coolant, those things have really long lives. Even more than most OAT coolants.
For your Dana 60 up front you can run either 80w-90 or 75w-90.
Lastly 4 quarts should be fine for your M275.
Old Feb 10, 2026 | 05:32 PM
augam's Avatar
augam
Contaminated brake fluid is a killer for ABS pumps. Not saying it is contaminated but these pumps not only have to be replaced due to contamination the software flashes typically are done at the dealer because of proprietary software.
Old Feb 10, 2026 | 05:51 PM
mattymax's Avatar
mattymax
AMSOIL website is pretty detailed on viscosity and how much your specific type will take.
Even if you dont like AMSOIL
Old Feb 10, 2026 | 07:15 PM
ruli00's Avatar
ruli00
Thank you everyone!
I added the brake fluid DOT 4 LV Motorcraft PM20 and a power bleeder and skipped the coolant for now.
Old Feb 10, 2026 | 07:22 PM
rufushusky's Avatar
rufushusky
Originally Posted by ruli00
Thank you everyone!
Power bleeders are great. I have the HF version of it and it is super handy.
Old Feb 10, 2026 | 07:25 PM
ruli00's Avatar
ruli00
This is in my cart but if there's a better option I'll try it
amazon.com/gp/product/B00942X5EI/ref=ox_sc_act_title_1?smid=A2IS69AN9A0OWP&psc=1
Old Feb 10, 2026 | 07:57 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Confirm My Fluids
Sounds kinky
Old Feb 11, 2026 | 08:02 AM
drj564's Avatar
drj564
I’m actively looking for a brake bleeder also. Most reviews on Damazon don’t inspire confidence. Any recommendations would be great.
Old Feb 11, 2026 | 08:51 AM
rufushusky's Avatar
rufushusky
I have had great luck with this one:
https://www.harborfreight.com/pneuma...kit-57057.html
I have used it for my brakes but also general fluid extraction, pumped out the hydrostatic oil from the transaxle in a lawn tractor I was rehabbing, extracting hydraulic fluid from my snowplow, etc
22 year old 20w50 came out looking like tar....
I have used this in the past but the handles always get brittle over time and break...
https://www.harborfreight.com/brake-...der-92924.html
NBT22555
May 16, 2014 05:50 AM
90pioneer
May 6, 2013 12:42 PM
George84
Dec 28, 2011 08:53 PM
dvfd12
23
Dec 1, 2008 07:07 PM
ttttmaxx
Nov 2, 2007 12:59 PM
