General Automotive Discussion
1999 e-350 rh head half exposed hole?
Old Feb 9, 2026 | 01:42 PM
asulwer's Avatar
asulwer
1st Gear
i have some pics of a 'potential' issue that i noticed with the intake and RH Head. there is a half-covered hole exposed. has an incorrect part been installed which allows this hole to be exposed? i looked at pics of the OEM intake and rh head and they appear to be the correct installed parts.
hole exposed.
Old Feb 12, 2026 | 10:42 PM
stammc's Avatar
stammc
3rd Gear
That hole may be an unused casting port or a blocked coolant/vacuum passage. If there are no threads inside and no coolant or oil leaking, it is likely normal for that head casting. Ford often used shared castings across multiple applications.
Old Feb 12, 2026 | 10:55 PM
Don Ridley's Avatar
Don Ridley
That is normal. Modular motor design.
Old Feb 15, 2026 | 03:29 AM
CathedralCub's Avatar
CathedralCub
FTE Community Team
Yep, normal.
This was actually the second question I asked when I was new here. Check this out: https://www.ford-trucks.com/forums/1...open-port.html
f250blueoval
Jun 4, 2024 11:47 PM
31smitty
Sep 21, 2022 03:37 PM
BeauF0RD
Jun 8, 2017 08:55 AM
coolguy1419
May 31, 2010 07:39 AM
82-100
15
Apr 28, 2009 08:29 AM
