Frame flex/bed gap
Old Jan 28, 2026 | 09:07 PM
Rombo's Avatar
Rombo
4th Gear
Frame flex/bed gap
I have a 1953 international cab mounted on a 95 f250 chassis. In progress installing a military trailer as a bed.
I know these frame flex a lot, I want to keep it fairly tight as I'm trying to make wheels wells centered.
What is the factory gap between bed and cab?
Old Jan 29, 2026 | 07:43 AM
97-psd's Avatar
97-psd
Mine measures 1 1/4” at the side between the bed and cab, and 1 3/8” at the center of the bed with the cab.
The stock bed is curved some so it is spaced to accommodate the flex. With your bed being completely straight, I would think you could be a little closer without risk of them contacting each other.
Old Jan 29, 2026 | 01:56 PM
knottyrope's Avatar
knottyrope
is that a KDX or KX back there?
Old Jan 29, 2026 | 03:14 PM
Rombo's Avatar
Rombo
4th Gear
Thank you sir, much appreciated!
Old Jan 29, 2026 | 03:16 PM
Rombo's Avatar
Rombo
4th Gear
Sure is, 95 Kdx 220. Things a two-wheel tractor, will chug through anything
Old Jan 29, 2026 | 03:51 PM
knottyrope's Avatar
knottyrope
me on my 97 220
Old Jan 29, 2026 | 07:02 PM
97-psd's Avatar
97-psd
That is a cool project truck. I would love to do something similar one day.
Old Jan 30, 2026 | 10:24 AM
Hit Man X's Avatar
Hit Man X
Oooo and IH truck
Old Jan 30, 2026 | 08:08 PM
TheFecalFanatic's Avatar
TheFecalFanatic
ooooooooh need a build thread, stat! Also assume you're gonna push the rear axle back a bit to line up with the bed wheel well?
Old Jan 31, 2026 | 09:42 AM
Rombo's Avatar
Rombo
4th Gear
It's getting really close to lined up with the bed gap tight.
The military trailer had a lip rolled forward, which I cut off and recreated with tubing on the inside. I think I will be with in 1/2", might just use a relocation plate https://cpaddict.com/products/sky-ma...s-ford-arp-001 to fine tune it.
Lizer
Apr 21, 2024 06:27 PM
393foxrn
Feb 26, 2024 02:17 PM
Vamisk
18
Apr 10, 2022 10:47 AM
arsetard
23
Nov 2, 2004 02:06 AM
