Headliner
Old Jan 28, 2026 | 03:18 PM
52burjes's Avatar
52burjes
Headliner
Hello, I am thinking about making my own headliner instead of using the cardboard ones available at lmc, d.c.,etc. I have the big rear window, so pictures show the headliner in 3 pieces. Given that the perimeter is screwed to cab roof all the way around. What holds the 2 side pieces in place where they join to the main piece, just something like 2 sided tape, or are they just wedged in place by pressure? Thanks.
Old Jan 28, 2026 | 06:25 PM
Byrd.Dog's Avatar
Byrd.Dog
Nothing holds the top of the side pieces to the roof portion. I recently re-did my headliner. I used the 1/8" particle board from Home Depot. 4x8 sheet for less than $20. I did a diamond-sewn pattern on the roof part & just plain vinyl for the side panels. Also added an aluminum strip along the top at the rear to help keep the material in place. Toughest part was trying to get all the curves to the boards right.
Old Jan 28, 2026 | 06:43 PM
52burjes's Avatar
52burjes
Thanks for the response. I've used the white plastic shower panels before, behind the seat, with good success. Might try it first on the roof. Not much more for it than a sheet of masonite. I guess the screws above doors, and the angle of the side pieces has enough pressure to hold them to the main piece. I will wrap them with cloth or vinyl. Thanks again, larry
Old Feb 2, 2026 | 07:33 AM
Tilleyman's Avatar
Tilleyman
Old Feb 2, 2026 | 03:30 PM
52burjes's Avatar
52burjes
Thanks, shows me what I've got to do. Is that pvc for the headliner or something else? Interior looks good.
Old Feb 2, 2026 | 03:36 PM
Tilleyman's Avatar
Tilleyman
Thanks. It's a herringbone Marine Vinyl Fabric spray adhered to the fiber board headliner. I got the fabric on eBay.
Old Feb 2, 2026 | 03:38 PM
52burjes's Avatar
52burjes
Did the fiberboard bend ok, and what kind of adhesive did you use for the vinyl?
Old Feb 2, 2026 | 03:43 PM
Tilleyman's Avatar
Tilleyman
the fiber board was only about 1/8" thick and easily conformed to the interior. I used 3M hi strength 90 spray adhesive.
Old Feb 2, 2026 | 03:44 PM
Tilleyman's Avatar
Tilleyman
make sure you spray both the board and the vinyl.
Old Feb 2, 2026 | 03:47 PM
52burjes's Avatar
52burjes
Thanks for the info. Much appreciated.
Old Feb 2, 2026 | 03:49 PM
Tilleyman's Avatar
Tilleyman
I also sound and heat insulated the roof and side areas with DynaMat.
Old Feb 2, 2026 | 05:06 PM
52burjes's Avatar
52burjes
I think I used cool-it on my 52. I'll definitely use one of them.
Old Feb 2, 2026 | 05:14 PM
Tilleyman's Avatar
Tilleyman
I had a 52 also!!
Old Feb 2, 2026 | 05:17 PM
52burjes's Avatar
52burjes
Mine's an f3. The bed looks cool, I'm guessing you made it yourself?
yeet
13
Feb 14, 2023 07:31 PM
Thiessen90
30
Jun 26, 2019 03:20 PM
19-F250-78
Jun 29, 2013 03:56 PM
tbm3fan
18
Jan 24, 2011 12:49 PM
Automator
Apr 26, 2009 11:51 AM
