WANTED: Outside Mirrors
Old Jan 28, 2026 | 02:46 AM
DaytonaTunnel's Avatar
DaytonaTunnel
I'm looking for a real nice, or better, set of FACTORY outside mirrors for my 79 F-150.
Old Jan 28, 2026 | 02:54 AM
DaytonaTunnel
I think this is in the wrong section, but I'll be darned if I can figure out how to delete it......
Old Jan 28, 2026 | 08:36 AM
tbear853's Avatar
tbear853
Looks like you have them, if that is your truck. They polish well, the arms were just anodized stiff aluminum, the bases chromed steel, the housings stainless steel, and the mirror glass if needed, is just set in rubber that is then pressed into the housing lip. I did it (after one of my originals broke after being dropped) with glass face down, rubber around it, then used a small screw driver to push in on the rubber while applying a little pressure on the housing pushing it down on the rubber. Was no glue originally, I put new glass in same way. I used a little Ru Glyde rubber lube. I ordered both to eliminate years of ice scraper scratches, etc ...... then applied a small round spot in the lower outer corner. Mirror Glass Plus
Old Jan 28, 2026 | 09:17 AM
DaytonaTunnel
That is on a truck I own, but need another pair.
Old Jan 28, 2026 | 06:34 PM
Viper Pilot's Avatar
Viper Pilot
Do you need originals? They make re-pops.
https://www.npdlink.com/product/outs...1975&year=1975
Old Jan 28, 2026 | 11:05 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
X2 repops if you want nice or better. If you buy cheap repops, that is what you will get. If you spend some $ on quality repops you can get a decent repop set. They are called (swing lock-top mounted-low profile) type 9's. And most repop mirror heads are 5 1/4 x 8 1/4. Sometime you can find the bigger 6x9 mirror head.
Parts Vendors & Resources
Dennis Carpenter Ford Restoration Parts
National Parts Depot:Ford Truck Parts & Accessories | 1948-1979
MAC's Antique Auto Parts
Blue Oval Truck Parts
Jeff's Bronco Graveyard
LMC Truck - Ford Truck Parts and Truck Accessories
The Early Ford Store-San Dimas,CA
Truck & Car Shop (Orange, CA): 48-86 Ford Trucks, 66-86 Ford Bronco
C&G Early Ford Parts: 32-79 Ford Trucks (Escondido,CA)
Sacramento Vintage Ford
Flashback F-100s: 48-2008 Ford Truck Parts
Vintage Pickup Truck Parts & Restoration Resources Directory
Green Sales Company - Vintage NOS & OEM Parts
Old Jan 29, 2026 | 09:17 AM
DaytonaTunnel
Yes, original is what I'm after....
Old Jan 29, 2026 | 09:23 AM
DaytonaTunnel
[QUOTE=77&79F250;21755965]X2 repops if you want nice or better. If you buy cheap repops, that is what you will get. If you spend some $ on quality repops you can get a decent repop set. They are called (swing lock-top mounted-low profile) type 9's. And most repop mirror heads are 5 1/4 x 8 1/4. Sometime you can find the bigger 6x9 mirror head.
I'm after originals. I purchased a pair from Classic Industies for another truck I plan to build. They looked "somewhat similar", but did not lock in place and the pivot points are reversed compaired to originals. Can you elaborate on your 'spend more money'? Not sure where to look? Not saying money is no object, I'm not afraid to spend money if the parts are correct and in mint, or REALLY good, condition.
Old Jan 29, 2026 | 09:55 AM
tbear853's Avatar
tbear853
Was a short lived delima here too, so after studying on it, I decided best just use the polishing wheel on the Shop Smith spindle after disassembly and cleaning. I even sanded / polished the chrome steel bases, then clear coated them. Made new base to door gaskets, my doors were new and while stored awaiting over 20+ years, I had installed steel strips with nuts welded on inside the doors, to spread loads.
Old Jan 29, 2026 | 10:03 AM
DaytonaTunnel
I have a pair that are pretty decent, but would love to find a MINT pair. I know that comes with a cost, which I can live with as long as I get what I pay for. It's for the 78 CC I've been working on for many many years. Have'nt cut any corners, and don't plan too.....
Old Jan 29, 2026 | 07:42 PM
77&79F250's Avatar
77&79F250
Originally Posted by DaytonaTunnel
I'm after originals. Can you elaborate on your 'spend more money'? Not sure where to look? Not saying money is no object, I'm not afraid to spend money if the parts are correct and in mint, or REALLY good, condition.
Maybe drop a WANTED add here for some OEM ones. https://www.ford-trucks.com/forums/1...de-wanted.html
Sorry I sold my last spare pair of type 9's I had in the parts shed. Here is the part # and I am sure these on hand #'s are very old, but worth a call anyway. Maybe they can run the # in their system and see if any one else has one or two.
Genuine Ford Parts:
D6TZ-17696-A .. TYPE 9 Low Mount Swing-Lock Mirror dealer installed kit / Obsolete
Last MSRP each: $58.33 / Dealer net cost each: $35.00.
TIM SHORT FORD in Hazard KY = 606-436-5239.
NOS PARTS LTD in Waxahachie TX has 1 = 972-937-2201.
KAMA OBSOLETE PARTS in East Bethel MN has 1 = 763-434-0123.
IPSWICH FORD in Ipswich MA has 2 = 978-356-9323.
TALLAPOOSA FORD in Tallapoosa AL has 2 = 256-234-3432.
Old Jan 29, 2026 | 07:46 PM
DaytonaTunnel
Thank you for the tips, I'll call then first thing!!!
AaronzDad
Feb 4, 2025 09:39 AM
Mtdentside
May 12, 2024 01:08 PM
OBS4ever
Mar 23, 2023 07:16 PM
judiecutie
Aftermarket Products
Sep 17, 2021 02:44 PM
Towlord
Apr 26, 2020 12:03 AM
