Ignition actuator problems
Old Jan 26, 2026 | 05:26 PM
1986bullnosebrian's Avatar
1986bullnosebrian
HELP! I can turn the ignition on, but the truck won't turn off when I flip the ignition cylinder switch back. I have to pull on the ignition switch actuator rod manually and hold the button. What must I replace? It's like something disconnected from the ignition cylinder.
File Type: mov
Old Jan 26, 2026 | 08:05 PM
Franklin2's Avatar
Franklin2
Piece #9 is what commonly fails and breaks in two. Steering columns are not fun to work on. You had better find a good youtube video to guide you through. Search for Ford ignition switch actuator replacement.
Old Jan 26, 2026 | 08:52 PM
JimsRebel's Avatar
JimsRebel
"Piece 9" is only used in tilt Wheel steering column.
Do you have a tilt Wheel?
Jim
Old Jan 26, 2026 | 09:06 PM
1986bullnosebrian
Jim
I believe so I have an 86’. By tilt wheel do you mean I can adjust the angle of the steering wheel?
Old Jan 26, 2026 | 09:21 PM
JimsRebel's Avatar
JimsRebel
Yes.
The wheel is spring loaded, you adjust it with the turn signal arm.
The hole the turn signal arm comes out will be triangle shaped.
'78F250351m
Mar 4, 2015 08:32 PM
squirrel64
Dec 6, 2013 07:25 PM
rmalottwtes30
Dec 30, 2010 11:54 AM
jellisproductions
Feb 2, 2004 03:10 AM
