Ignition Switch
Old Dec 27, 2010 | 12:48 PM
rmalottwtes30's Avatar
rmalottwtes30
Ignition Switch
What are the symptoms of a bad ignition switch?
My truck shut off yesterday, now it wont start, it will crank over though.
Old Dec 27, 2010 | 03:33 PM
mikeismadness's Avatar
mikeismadness
hmmm im not to sure on your truck...but on the driver side fender there is an ignition module on gas trucks...mine went out and would turn over all day but wouldnt fire..not to sure about the ignition switch or if u have an ignition module
Old Dec 28, 2010 | 08:25 AM
richdavis69's Avatar
richdavis69
If your truck has a shroud around ignition switch it is an easy and inexpensive switch out. There is a pin on bottom of cylinder that when in the run position will push in and allow the cylinder to pull out. New cylinder pops in the same way.
Old Dec 30, 2010 | 11:18 AM
unibody62's Avatar
unibody62
My key is very stiff when turning and does not really return to the "neutral" spot after starting, (I have to help it out). Will replacing the lock cylinder fix this or is it a deeper problem.
Old Dec 30, 2010 | 11:54 AM
richdavis69
the ignition switch is like $12.99 and take fifteen minutes to do if you have a shroud around steering column. If end of cylinder switch is worn check inner gear for the metal buildup and clean. Once shroud is removed put ignition switch in run position and press locking button from beneath with small drill bit or pick. goes in the same way
