sticking ignition
Old Dec 6, 2013 | 01:43 PM
squirrel64's Avatar
squirrel64
sticking ignition
Hey guys,
Got a 1985 F350 6.9l ton truck. I keep burning up starters and I'm thinking that the ignition switch is the culprit. I have to manually turn the switch back as it does not return by itself after starting the truck. This is a new switch as I had replaced the old one thinking that would fix it. I was wondering if someone may know where or what could be making it stick like that.
Old Dec 6, 2013 | 07:25 PM
Phy's Avatar
Phy
If you changed the actual ignition switch, the problem is probably in the key cylinder or actuator. If you changed the key cylinder, the problem is probably in the ignition switch...
broadhek
2009 - 2014 F150
Apr 10, 2017 05:01 PM
Daddywags
Oct 19, 2011 10:38 PM
brknight
Jan 2, 2011 09:13 PM
rmalottwtes30
Dec 30, 2010 11:54 AM
