First gear problem
Old Jan 22, 2026 | 03:52 PM
mark a.'s Avatar
mark a.
First gear problem
2008 Ranger 4x4 5 speed 135k miles. Lately it's been Getting hard to get into first. It doesn't grind and letting the clutch out and trying again makes no difference. Other than that the trans works fine and the clutch was replaced 40k ago. Any ideas what is going on ?
Old Jan 22, 2026 | 05:53 PM
BareBonesXL's Avatar
BareBonesXL
I had a similar porblem with my M5OD after changing transmission fluid to Valvoline Mercon V. I ended up draining it and switching to Pennzoil Synchromesh, which fixed the problem You might try just changing fluids, maybe yours is old or contaminated, or just low. Don't use Valvoline though.
Old Jan 24, 2026 | 01:21 PM
mark a.'s Avatar
mark a.
As far as I know it's never been changed so I will try that.
Old Mar 16, 2026 | 07:03 PM
mark a.'s Avatar
mark a.
Took it a while to work in but it shifts good now. I used the Pennzoil.
rquinlans
Apr 24, 2011 11:38 PM
97RangerFTW
13
Mar 19, 2010 10:50 AM
Taumac
Jan 6, 2009 09:33 AM
steve381
Bronco II
Apr 21, 2005 12:39 AM
mikewf250
Feb 6, 2005 10:07 PM
