Hood repair
Old Jan 20, 2026 | 03:47 AM
R&S20's Avatar
R&S20
Hood repair
Has anyone replaced a portion on the inner skin/support on our hoods. Specifically the passenger front corner above the battery. I can't find it made repop.
if anyone has that front corner on a hood that they are willing to cut out and sale please let me know.
Just the inner it seems that years of battery fumes has worked over the one I have.
Old Jan 20, 2026 | 04:54 PM
73explorer's Avatar
73explorer
It should be easy to find a replacement hood. Why not just go that route?
Old Jan 20, 2026 | 05:35 PM
R&S20's Avatar
R&S20
I have a repop hood and it is not stamped correctly. The body lines do not match up. And it was not cheap. I am getting a OEM hood ready to replace the Chinese hood I have.
These original parts are not available in the area that i live in. To the extent that i hauled this one approximately 400 miles home. These are not even available in salvage yards here. So i was hoping a member here had one that they didn't feel like was usable and would be willing to cut out and sell the small piece that I would like to replace.
Old Jan 20, 2026 | 09:52 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Yes gotta get a new quality repop hood,$$$$, used OEM or get some one to cut you a patch panel is the only option. I have never seen the inner hood reinforcement reproduced.
Old Jan 21, 2026 | 04:56 AM
manicmechanic007's Avatar
manicmechanic007
For as much as hoods cost and the potential crappy fit, I'd fab up some metal and fix the bracing on your existing hood
However, I am with you on looking for new metal
Junkyard is your best bet, and I'd just get the bracing, cut the spotwelds out with a special spotweld drill bit
Old Jan 21, 2026 | 05:28 AM
Fleur de lis 82's Avatar
Fleur de lis 82
Where are you located, I might have one that I can cut up out of the hood from the truck the wife rolled. Drivers side of the hood took a good hit, but the passenger side area you need may still be good.
Old Jan 21, 2026 | 07:55 AM
R&S20's Avatar
R&S20
Fluer di les, I sent you a message
rharmon
Mar 2, 2025 08:21 PM
riderboy1961
Jun 2, 2024 12:17 PM
okiewelder
1961 - 1963 F100 Unibody
Oct 9, 2015 11:35 AM
Sanford3
May 3, 2004 10:48 AM
