Dashboard Notices/Warnings
Old Jan 18, 2026 | 02:16 PM
D.Yaros's Avatar
D.Yaros
My truck is a 2019 F-150 XLT. It has 74,700 miles on it. The truck is "new to me, having been purchased in July of 2025. I have put a total of 400 miles on it since purchase.
Suddenly I am getting a slew of dashboard notices/warnings: Hill Assist Not Available, Pre-collision Assist Not available, Service Stability Control and ABS.
The truck functions normal, despite the warnings. I find it hard to believe that all these functions went bad at the same time.
Could I be getting all these notices/warning at once be a sing that my battery is going bad? Could there be some other cause for this to happening?
Old Jan 18, 2026 | 03:33 PM
JKBrad's Avatar
JKBrad
I would start with checking the ground strap leading from the battery to the frame or body to the frame. Look for any signs of corrosion, or looseness. Then I would check the condition of the battery. A weak battery will cause all sorts of strange electronic issues, especially on Fords.
Old Jan 18, 2026 | 04:45 PM
SpencerPJ's Avatar
SpencerPJ
I'd almost be certain it is your battery. Might (likely) only needs charged, or a good interstate run. If it is the original, just replace it.
Old Jan 18, 2026 | 09:57 PM
hihosilver13's Avatar
hihosilver13
Trailering
Battery for sure. Had the same thing.
Old Jan 19, 2026 | 11:47 AM
GlueGuy's Avatar
GlueGuy
+1
Add my voice to the chorus. Battery or loose ground strap as suggested.
Old Jan 22, 2026 | 12:42 PM
D.Yaros's Avatar
D.Yaros
Got it. Thanks!
Old Feb 27, 2026 | 04:40 PM
Papasmurf429's Avatar
Papasmurf429
3rd Gear
Originally Posted by GlueGuy
+1
Yeah having the same to mine battery is about 3ish years old, so a good charge should fix that?
Also is the battery minder thingy on the ground side attached to the ground terminal?
Old Feb 28, 2026 | 08:25 AM
fordwrench91's Avatar
fordwrench91
Trailering
A 3-year battery could still be fine, but at that age with those symptoms I would get it load tested before just charging it. A surface charge can make a battery test good on voltage but still fail under load. Takes 5 minutes at any auto parts store for free.
For the battery minder connector - on the 2019 F150 there is a remote positive terminal up front near the fuse box in the engine bay. That is actually there specifically for jump starting and charger hookup so you do not have to dig down to the battery. The ground side you just clamp to any clean metal on the chassis - the battery tray bracket or a bolt on the firewall works fine.
Once you sort the battery out, those warnings should clear on their own after a few drive cycles. If they do not clear after the battery is confirmed good, then it is worth pulling codes to see if there is something else going on.
Old Feb 28, 2026 | 04:11 PM
D.Yaros's Avatar
D.Yaros
No, the Battery Tender + charger is connected directly to the Pos (+) and NEG (-) terminals of the battery. Does that make a difference?
LoHi
Jun 26, 2022 02:41 AM
jonesky
1997 - 2003 F150
May 10, 2015 07:04 PM
dfooch
Oct 14, 2008 06:25 AM
tapper95
Oct 9, 2007 10:58 AM
rodger932
Dec 29, 2003 01:54 PM
