Sponsored by: Real Truck
E-Brake replacement process
Old Jan 18, 2026 | 02:04 PM
PJWhelan's Avatar
PJWhelan
Is it possible to replace E-brake pads, springs,clips without removing the axles shaft? Seems hard to do with it still being in place. 2002 Ford F-250 CCLB, 250,000 miles
Old Jan 18, 2026 | 02:45 PM
lwitiver's Avatar
lwitiver
4wd Low
You can, but it's probably easier (and maybe cheaper) to do all of it, including backing plates (which requires removing the axles....not a bad idea to replace the axle seals...mine were toast.) You can get new backing plates with all the hardware preinstalled (loaded backing plates) from RockAuto for about $150 each
There's a how to at the following link:
brake backing plate how to
Old Jan 18, 2026 | 03:14 PM
PJWhelan's Avatar
PJWhelan
When you did the work, how long did it take you? Both sides done in one day??
Old Jan 18, 2026 | 04:23 PM
lwitiver's Avatar
lwitiver
4wd Low
Yes. Took me a day to do both sides. It's not difficult as long as you have the correct tools. You'll need the correct spindle nut socket for your axle, a parking brake cable disconnect tool, and a 3 jaw puller to remove the spindle (it must come off to change the backing plate)
My truck is a 1999 f350SD 7.3DSL Ex Cab 4 x 4
Old Jan 18, 2026 | 08:13 PM
PJWhelan's Avatar
PJWhelan
Having not removed the axle shaft.....ever....is it a 4 tooth external socket that enables you to remove the outer bearing seal? Are there 2 bearing per side? Rookie question: Once you pull out the axle shaft, there is an axle nut, bearing and a bearing on the other side of the knuckle? Do I have that right? I need to order new sets for each side of the rear axle as this job has never been done by me and I am the original owner of this 24 year old stallion..:)))
Old Jan 18, 2026 | 08:58 PM
INFRNL's Avatar
INFRNL
There is only an inner and outter bearing once the lock nut is removed.
Not the best video but watch this to see how it's done
Old Jan 19, 2026 | 11:26 AM
PJWhelan's Avatar
PJWhelan
I have seen that video before from TRQ and love that rust bucket. I 'm not sure what was holding that truck together all those years. Seems like the the tires did the glue job. Okay, I see the bearings and seal in the back.
Old Jan 19, 2026 | 03:37 PM
lwitiver's Avatar
lwitiver
4wd Low
The retainer nut is the 4 pin job. Inner and outer bearings/races only, and 1 seal per side. Once you take the hub bolts off, the axle just slides right out. When you reinstall it, you have to wiggle it a bit to get the splines lined up but it's not a big deal
khaynes
Oct 21, 2025 10:31 PM
jasonodsky
Nov 20, 2010 12:03 PM
jkuelper
1983 - 2012 Ranger & B-Series
Mar 31, 2008 08:54 PM
lbrendel81
Aug 9, 2004 12:37 PM
