Front Axle UJoint Replacement
Old Nov 19, 2010 | 02:54 PM
jasonodsky's Avatar
jasonodsky
I'm about to pull apart the drivers side to replace the stub shaft (needle bearing is shot and took the stub with it). I've reviewed all the great tutorials here and from Guzzle so I'm ready for what to expect. However, I have not found good instructions on replacing the ujoint in the front axle.
So are there any tricks or traps I need to watch for?
Looks like there are caps on the ends of the joint but I'm not sure (don't have a manual). The motorcraft ujoint does not have a zerk so is it pregreased?
If there is not a good tutorial, I'll take pics along the way.
Thanks! Jasonodsky
Old Nov 19, 2010 | 05:16 PM
jasonodsky's Avatar
jasonodsky
OK Cancel my request. I just happened upon a great tutorial for this here
2004 F250 Front Axle U-Joint Replacement
Old Nov 20, 2010 | 08:03 AM
Magilla_v6.0's Avatar
Magilla_v6.0
I would reccomend getting a better u-joint like a spicer that has a grease zerk.
Old Nov 20, 2010 | 12:03 PM
jasonodsky's Avatar
jasonodsky
The Motorcraft replacement is a speicer. It has SPR stamped on it. the first one made it 152k and I'm only replacing it because the stub shaft was damaged by an unmaintained needle bearing. Thanks for the suggestion.
ztodd377
Jul 20, 2017 06:40 PM
Steven Stocki
Nov 27, 2016 09:39 PM
jasonodsky
Sep 21, 2016 09:33 PM
reamer
Mar 23, 2016 03:33 PM
dpilot83
Dec 23, 2015 09:43 AM
