Autolite 2100 casting no.'s
Old Jan 17, 2026 | 05:39 PM
elbow grease's Avatar
elbow grease
I just picked up a used Autolite 2100 1.23 venturi carb and have looked everywhere (almost) and can't find any info on this. Directly below the 1.23 on the side of the carb still within the circle is embossed in capital letters "TR". So it's 1.23 over TR, all inside the circle on the side of the fuel bowl. There is no tag on the carb but the no.'s stamped on the front drivers side leg are 9T-J which I think dates the carb to 1969, and from what I've found looks like was used on the 360 and 390 engines with manual transmission?
Any info on the "TR" cast directly below the 1.23 would be very interesting, as I have never seen this before on any 2100 or 2150 carbs and it's got me curious to say the least. Thanks to you guys and gals in advance!
Old Jan 18, 2026 | 04:17 PM
barnyard's Avatar
barnyard
here is an old post from a different forum. 64 tboltd says the "tr" indicates a truck carb.
64 TBOLTDiscussion starter
3,546 posts · Joined 2001
#6 · Oct 25, 2002Image
The 1.23 is the venturi size,TR is truck.The date code is on the foot(8T AZ).There was also a 1.33 that was in 66 only.This one is going in the ACID tank
Old Jan 18, 2026 | 04:43 PM
elbow grease
Thanks for that, actually I have seen that post but it really doesn't make sense to me as there were TONS of "truck" carbs put out in the '50's-'80's that don't have "TR" cast into the side of the fuel bowl.
75 F100 4X4
Sep 15, 2020 01:41 PM
tomohara
Oct 6, 2014 12:46 PM
tmcalavy
Jan 4, 2012 06:06 PM
keebler67
Nov 24, 2003 07:49 AM
mypa'struck
Sep 8, 2003 06:07 PM
