Cam Replacement Help needed
Old Jan 23, 2026 | 06:00 PM
FuzzFace2's Avatar
FuzzFace2
Bronze is a little harder than the Babbit type bearing used for the cam, crank & rods, so I dont think I would use a file in non-trained hands but that's just me.
Dave ----
Old Jan 23, 2026 | 06:05 PM
DaveMcLain's Avatar
DaveMcLain
When you press the new gear onto the new camshaft be careful not to break the thrust plate.
Old Jan 23, 2026 | 07:04 PM
FuzzFace2's Avatar
FuzzFace2
It looks metal to me or do you mean bend it?
Dave ----
Old Jan 23, 2026 | 07:29 PM
DaveMcLain's Avatar
DaveMcLain
They are cast iron, pretty hard and they can break very easily.
Old Jan 24, 2026 | 03:34 PM
FuzzFace2's Avatar
FuzzFace2
Oh ok cast iron would be a problem then.
Dave ----
Old Jan 24, 2026 | 03:44 PM
DaveMcLain's Avatar
DaveMcLain
You just have to be careful how you support the camshaft and keep checking to make sure that you're not bearing on or catching the thrust plate in some way. A Chevy 6 cylinder is almost exactly the same.
Old Apr 14, 2026 | 11:12 AM
Grey89F150's Avatar
Grey89F150
Does anyone know the part number for the spacer ring that goes in between the thrust plate and cam gear?
I'm trying to get the fiber gear off the old cam, but it's stuck on there bad.
And I ordered the wrong thrust plate too.
Old Apr 15, 2026 | 06:22 AM
Grey89F150's Avatar
Grey89F150
Will Melling S802SP Stock Replacement Thrust Plate Spacer work?
octaneforce
24
Feb 18, 2011 11:15 AM
octaneforce
13
Nov 6, 2010 06:57 PM
wmiller
Aug 21, 2009 04:51 PM
cjben
Feb 13, 2005 09:59 PM
sturzinator
Nov 30, 2001 05:30 PM
