Cam Phaser Questions
Old Jan 6, 2026 | 06:46 PM
TheDarKnight's Avatar
TheDarKnight
4th Gear
I have a 2009 F150 with the 5.4 triton that I'm working on for a friend, the way it was running it sounded like bad cam phasers or solenoids. But after taking the cable covers off the try replacing the solenoids we found that there had already been a lock out kit installed, what would cause it to run like that still. It runs really rough and will occasionally rev up to 2k and then just shut off.
Any help is greatly appreciated.
Old Jan 6, 2026 | 07:23 PM
Johnny Paycheck's Avatar
Johnny Paycheck
Lockouts require a tune to keep things running even remotely okay.
Odds are that wasn’t applied to that band-aid fix (lockouts).
The engine has likely been running out of time for a long time (think misfires and cat converter damage) and has been running low on oil pressure for just as long. Metal on metal noises? Think lots of metal floating throughout the engine.
I’d be hesitant to put a dime into this engine.
Old Jan 11, 2026 | 07:29 PM
stephen.osborne1's Avatar
stephen.osborne1
Could also have a bad chain guide or tensioner causing timing issues.
2015 F-350
6.2L V8
Mar 27, 2025 06:24 AM
modrummer
2004 - 2008 F150
Feb 21, 2022 09:45 PM
troy's66customcab
Mar 31, 2011 09:08 PM
88grandmarquis
Jun 24, 2004 06:38 PM
ranchero77
Mar 9, 2004 08:26 PM
