anyone running a comp cam?
Old Jun 20, 2004 | 07:13 AM
88grandmarquis's Avatar
88grandmarquis
I've thinking of checking into one for the '86 F-150 EFI 302. I'd like to get more out of this engine (only 8,000 miles on it since an overhaul). Any pros/cons or experience with the Comp Cams? Any tips on changing out cams? All info is appreciated. Thanks.
Old Jun 20, 2004 | 08:07 AM
71swissaqua's Avatar
71swissaqua
I'm running one of their Exteme 4x4 cams and am happy with it. I recomment that you call them and get their opinion. I also suggest talking to some of the custom cam grinders
Clint
Old Jun 20, 2004 | 11:13 AM
94F150-408's Avatar
94F150-408
Yes, I've had a few different CompCams and I'm happy with their performance. You'll want to give their techHelp line a call and ask them which cam they would recommend for your configuration and your goals.
Old Jun 21, 2004 | 10:21 PM
robduval's Avatar
robduval
i'm running one. it's a custom grind, we just toredown the engine after about 500 hard miles most on the strip and the cam is still mint. if you have any mods make shure to let them know so they can grind the cam to what you need. you'll get more power this way than buying an off the shelf cam.
Old Jun 22, 2004 | 05:42 PM
88grandmarquis
I called Comp Cams and they said the only one they really have for the EFI 302 is the 31-255-5. Checked on Summit for prices:
$154.39 - cam
$85.88 - lifters
$63.88 - valve springs
$59.39 - spring retainers
$6.95 - valve locks
$15.95 - valve seals
$386.44 - total
I debating if I should do this to the '86 F-150. I'd rather use the '86 as the guinee pig since I don't use it as much as I use the car. Any suggestions? Since the trucks' engine only has 8,000 miles on it, do you think I should have to replace the springs and such, too?
Old Jun 22, 2004 | 07:12 PM
robduval's Avatar
robduval
it depends on the new cam. if the lift is alot higher the springs will bottom out and bad things happen. also if the duration is longer you will want a better spring.
Old Jun 22, 2004 | 07:15 PM
88grandmarquis
Here's a link to the specs: Comp Cam
I'm not sure what the current stock cam is. Anyone have that on hand?
Old Jun 22, 2004 | 10:00 PM
robduval's Avatar
robduval
you should be fine with the stock springs as long as your not running it at red line. i thought the cam lift would be in the 300 area. don't know why i was thinking that. i'm running a .588 lift cam on bolth intake and exhaust with 112 deg of seperation. even being efi it doesn't like to idle so i'll be calling com cams back on that one soon. good luck and keep us posted.
Old Jun 23, 2004 | 04:06 PM
88grandmarquis
What is the lift and specs for the stock cam on the EFI 302? I'm new to this cam stuff. More lift is better, correct? I just want to make sure that this Comp Cam will show a fair amount of improvement over stock. I'm pretty sure that the 31-255-5 cam will be going in my Grand Marquis when the time comes for an overhaul. Not sure if I should run it in the truck, too.
Old Jun 24, 2004 | 01:59 AM
robduval's Avatar
robduval
yes more lift is better but to much is also bad (that's when pistons and valves get intimate and the end result is ugly) duration is how many degrees of turn that the valve is held open. the cam for your truck is most likely going to be a little bit of a different grind. as for the stock specs i'll try and find them.
Old Jun 24, 2004 | 06:38 PM
wantmuscle's Avatar
wantmuscle
The high lift, short duration cam is disigned for what you got... stock heads with small restrictive ports. The exaust port are really small and restrictive. That is the reason for the split duration (valves open longer and lift is higher on the exaust). Looks like a pretty good choice numbers wise, but I'd still call their tech line for a perfect match. With lift any higher than that cam's will start to tread into the valve/piston marrage rob talked about, plus add unneeded strain to the valve train. That, and anything bigger will kill low end, and you'll be driving a dog that sounds good. Unless you want to start spending the $$$ for heads, gears, converters, etc...
Not sure whether the factory computer will like the cam though. That is one of the best reasons to call the cam tech line.
