weird trailer issue when activating brake controller
Old Jan 3, 2026 | 05:51 PM
CoF2502026's Avatar
CoF2502026
4th Gear
I've just made the switch to a 2020 F250 for towing purposes.
I was testing out the trailer (just a typical 6x12 trailer with elec brakes).
Plug the trailer in, test indicators, brake lights by pushing the brake pedal, emergency lights, everything works, trailer is 'connected'
I squeeze the brake controller (the manual thingy) and the trailer IMMEDIATELY 'disconnects'.
What gives?
Trailer worked fine on previous truck (F150) - though that truck did not have a brake controller.
Visually inspected the truck plug on the F250, no damage to wires, inside of the plug is extremely clean, zero corrosion.
Anyone else had this?
Old Jan 3, 2026 | 07:11 PM
bigwin56f100's Avatar
bigwin56f100
I can't explain it as I don't fully understand but the system on the trailer monitor/controller is very sensitive.
my example:
my 2005 f150 everything worked fine, hook up to my then new 2022 f250 and the same EXACT thing occurred.
long story short, I had shorted wires. The wires that on my trailer were routed thru the axle tube for the other side brakes had rubbed thru inside the axle tube.
these new trucks somehow sense when there is a problem
I didn't believe the dealer because the trailer still worked on my f150
i pulled the break away cable out of the switch and about 10 minutes later I had a melt down in the break away switch.(I had wired a battery direct hot and ground)
I then started re-wiring and that's when I found the bad wires in the axle tubes.
all good now.
I can just about guarantee it's a trailer problem
Old Jan 3, 2026 | 09:09 PM
CoF2502026's Avatar
CoF2502026
4th Gear
Thanks for the reply brother!
I crawled under the trailer, and yep, sure enough, a couple of the wires coming out of the trailer hubs are broken.
Ill test by hooking up to a friends trailer in the next few days to verify there is no truck side issue.
Old Jan 4, 2026 | 09:23 AM
bigwin56f100
so long as the trailer # 2 doesn't have any issues. I fought this for a whole summer because the 2005 f150 worked fine and the superduty didn't. I just couldn't believe it was a trailer problem but it was.
Old Jan 5, 2026 | 11:42 AM
99powerstrokedF250's Avatar
99powerstrokedF250
Many older trailers are showing issues with newer trucks, just like this. It's barely a short, but enough for the sensitive modules in newer trucks to pick them up and kick out errors like this. It's an overly-sensitive system in my opinion, but there isn't much that can be done to change it.
Old Jan 5, 2026 | 08:30 PM
The Peddler's Avatar
The Peddler
I have this problem, only with my boat trailer that has EOH brakes. No problem with the utility trailer, the RV, or the car trailer I borrowed. The brakes still seem to work fine, but occasionally get the "Disconnected" message as I come to a stop, and if I manually apply them.
Old Jan 11, 2026 | 07:14 PM
mates's Avatar
mates
4th Gear
I'm seeing the same issue on my f450 with my 5th wheel. Trailer brakes are working normally. But this occurs when activating the brake manually...trying to figure it out.
Old Jan 11, 2026 | 10:01 PM
The Peddler
Does your 5’er have basic electric or electric/hydraulic brakes?
Old Jan 12, 2026 | 09:20 AM
mates's Avatar
mates
4th Gear
Electric over hydraulic ... and it is set in the trailer configuration.
Old Jan 12, 2026 | 07:20 PM
The Peddler
Same… interestingly I don’t have the problem if I run the brakes under the “electric” setting, but then the EOH pump runs constant even when truck wheels aren’t rolling. (Traffic light, etc) The EOH setting drops the brake voltage to zero when the truck isn’t rolling, so the pump doesn’t run.
WillyFord
All Things Towing
Oct 21, 2025 09:10 AM
shelhart
All Things Towing
May 13, 2024 12:34 PM
stydel311
2004 - 2008 F150
May 31, 2022 03:11 PM
carolinaborn82
2009 - 2014 F150
May 25, 2017 05:26 PM
offrdmania
Feb 18, 2010 07:29 PM
