Speedometer Issues
Old Jan 3, 2026 | 03:25 PM
csmeby's Avatar
csmeby
4th Gear
Speedometer Issues
Hi everyone
Since I've had my truck the speedometer has never worked. We've replaced the speedometer cable (original one was snapped in half anyways), the gear that goes on the cable, and finally the speedometer/odometer itself. Going for a drive today, it started off not moving at all - but the odometer was working. Eventually it started bouncing around a little, and then it started to go from about 5-20 pretty reliably, but not really past that. Does it just need to align itself somehow?
Old Jan 3, 2026 | 04:28 PM
blue68f100's Avatar
blue68f100
Have you checked the gear in the transmission?
Did you lube the cable when you installed the new one? Or did you replace the outer shield and cable as an assembly?
Rocktroll
13
Mar 17, 2023 11:11 PM
JoelStobbe
Sep 28, 2022 06:47 AM
Connecticut Calvin
Sep 13, 2016 12:05 PM
52 F1 Stocker
Oct 21, 2015 08:20 AM
