Electrical Connector Removal Tool
Old Jan 2, 2026 | 09:18 PM
350Recon's Avatar
350Recon
The electrical connections under the rear near the spare tire are a problem with some trucks when they get contaminated. I have to disconnect them to remove the tailgate to mount my truck camper.
I just leave them disconnected for easier tailgate removal because what a pain in the rear they are to remove.
Looking through some information I came across these tools. Has anyone used them?
Maybe everyone knew about them and I just found them.
Old Jan 2, 2026 | 09:27 PM
ds53652's Avatar
ds53652
I have a similar set. I've used the two in your 2nd and 3rd pics. I've found them VERY helpful!! I'm always afraid of pulling on the wires inadvertently...these tools help greatly with that.
Old Jan 3, 2026 | 07:54 PM
1olddogtwo's Avatar
1olddogtwo
I have the same ones in pics two and three, I'd give them a thumbs up.
Old Jan 5, 2026 | 06:30 AM
Neohio's Avatar
Neohio
www.DieselCurrent.com
Be careful with the plier style remover.
I have seen them slip off the connector and cut the wires.
They definitely work, just be aware they may do damage if they slip.
Old Jan 5, 2026 | 07:40 AM
dzdiggin'dude's Avatar
dzdiggin'dude
Can someone post a link to them? Looks handy to have in the tool box.
Old Jan 5, 2026 | 03:33 PM
350Recon's Avatar
350Recon
Amazon Amazon
A lot to choose from.
Old Jan 14, 2026 | 01:08 PM
acdii's Avatar
acdii
There is a far less expensive method to separating electrical connectors. PUSH, don't PULL The clips to unlock are not difficult to unlock if you first push the shells together, then press the release tab. When disassembling the parts on an engine, I find it so easy and never needed tools except maybe a pick to pull the release locks out from the coil packs, then push on the connector, then press the release tab, they pop right off. its the pressure of the watertight seal that makes them difficult to remove.
PunksSuperDuty
Apr 12, 2022 05:00 PM
79calicruiser
1978 - 1996 Big Bronco
Feb 27, 2022 06:11 PM
BatteriesNotIncluded
Feb 22, 2019 04:27 PM
InkMing
Mar 19, 2018 11:53 AM
FordF350Baby
Jan 16, 2009 01:38 PM
