Engine Issue
Old Dec 30, 2025 | 12:20 PM
Omni43's Avatar
Omni43
Engine Issue
I have a 1972 250 with a newly rebuilt 390. The engine was run on a stand at the engine builders before I put it back in. Ran very well. I started the truck up of the first time the other day and just drove it for few minutes to verify that things were OK. It ran fine.
The next day I came out cranked it over and it was a different story. It would crank a couple of revolutions and then stop. I hit the key again and it would crank again with less power and again stop rotating.
I put a new starter in it, and a new battery and no change. Does anyone have any other thoughts of else I could check out?
Old Dec 30, 2025 | 12:24 PM
85e150's Avatar
85e150
Flat tappet cam?
Check the oil for metal.
Old Dec 30, 2025 | 12:56 PM
jzjames's Avatar
jzjames
Engine rotate? Remove plugs and verify.
Old Dec 30, 2025 | 03:06 PM
Omni43's Avatar
Omni43
Yes, FTC, no metal in oil.
Old Dec 30, 2025 | 05:26 PM
blue68f100's Avatar
blue68f100
Bad ground or cable. Starter solenoid. Put the new battery on a charger and make sure it's fully charged.
Old Dec 30, 2025 | 06:46 PM
Omni43's Avatar
Omni43
I got plenty of grounds, fully charged battery. Did not check the solenoid.
Old Dec 31, 2025 | 05:27 AM
JPG37's Avatar
JPG37
Kinda sounds like the engine is out of time as if maybe the distributor turned on you.
Old Dec 31, 2025 | 09:00 AM
Omni43's Avatar
Omni43
Thank you, someone else was telling me that too. I'm going to look into that when I get a moment.
Old Jan 1, 2026 | 08:30 AM
Omni43's Avatar
Omni43
You were right I moved the timing a bit and it fired up immediately. Here I was thinking there was internal damage to the engine.
Old Jan 2, 2026 | 03:50 PM
Wangdangdoodle's Avatar
Wangdangdoodle
This kind of thing is not uncommon when rebuilding things. Something gets put together, but never tightened down because you think " I'll get that later". I've made it a habit to recheck nuts and bolts to make sure they are torqued before I close something up for the last time. Good thing it was something that did not cause damage.
Old Jan 3, 2026 | 08:32 AM
Omni43's Avatar
Omni43
It was tightened down, the timing was just wrong.
The Peddler
Jun 27, 2023 06:44 AM
Elizondo62
Aug 24, 2011 06:02 PM
Timmy101
Mar 11, 2011 09:43 AM
bdewbre
Sep 12, 2005 08:49 PM
cadiecast
Aerostar
Jun 26, 2002 07:49 AM
