PCV Change Over
Old Jan 27, 2026 | 05:56 PM
  #31
KULTULZ's Avatar
KULTULZ
You know something? I didn't even notice that as I was pointing out the valve vacuum port. Yes, the spacer design does have an effect but that is for more for a performance engine and not a driver. But whichever spacer is used, the vacuum port needs to connect to both spacer throttle bores.
The early road draft was a terrible design for efficient CCV. That is one reason it marks its territory as did the later breather tube design.
Old Jan 28, 2026 | 02:04 PM
  #32
Sprocket118's Avatar
Sprocket118
I was thinking I could drill into the center of the phenolic one, then break into each bore since the material is easier to machine. I'm still in the planning stage so these ideas and bits of information are very useful!
MikeBH
Sep 7, 2025 07:14 PM
stephen.osborne1
21
Nov 23, 2021 02:11 PM
brendaf150
Dec 22, 2012 02:32 PM
t_hess66
Mar 29, 2012 02:19 PM
abreiholz
Nov 15, 2010 11:51 PM
