Sponsored by: Real Truck
Need help
Old Dec 29, 2025 | 06:14 PM
Waysm's Avatar
Waysm
1st Gear
Need help
I have a 2000 f250 and its having some problems long list the headlights and the dash gauges quit working windows work fuses have power and continuity through them when I’m driving and when I stop the door dinger goes crazy and the door locks go crazy alternators is charging at 14.5 like it’s supposed to just put a fresh set of batteries in because the others were getting pretty old any info would be appreciated
Old Dec 30, 2025 | 09:19 AM
bajaphile's Avatar
bajaphile
Hey Waysm,
You will get responses if you put in a bit more effort in your request. Put in a little more time with your grammar and exactly what is happening and what you've done. I read your run on sentence a few times and am lost on what you're asking. Maybe copy paste that into ChatGPT and it might figure it out
Old Dec 30, 2025 | 03:25 PM
crashz's Avatar
crashz
Yeah the run-on sentence is a little tough to follow. I always start with grounds. Clean and check all the grounds from the battery to the chassis and body. The another thing to look at is the fuse panel in the cab. The windshields are known to leak and cause the wiring and connectors in the fuse boxes to corrode.
Old Dec 30, 2025 | 04:30 PM
Old and soft's Avatar
Old and soft
And behind that fuse panel is the gem that controls a lot of the interior functions. Radio, locks, windows, wipers....
Dave 78 F250 460 2WD
Jun 5, 2025 08:43 AM
gabriell12123
Electrical Systems/Wiring
Apr 19, 2022 07:17 AM
spdmpo
Jul 27, 2009 01:21 PM
Ginger2000
1997 - 2003 F150
Apr 18, 2007 09:04 AM
polar88
Mar 28, 2006 08:43 PM
