I have a 2000 f250 and its having some problems long list the headlights and the dash gauges quit working windows work fuses have power and continuity through them when I’m driving and when I stop the door dinger goes crazy and the door locks go crazy alternators is charging at 14.5 like it’s supposed to just put a fresh set of batteries in because the others were getting pretty old any info would be appreciated
Hey Waysm,
You will get responses if you put in a bit more effort in your request. Put in a little more time with your grammar and exactly what is happening and what you've done. I read your run on sentence a few times and am lost on what you're asking. Maybe copy paste that into ChatGPT and it might figure it out
Yeah the run-on sentence is a little tough to follow. I always start with grounds. Clean and check all the grounds from the battery to the chassis and body. The another thing to look at is the fuse panel in the cab. The windshields are known to leak and cause the wiring and connectors in the fuse boxes to corrode.
