headlight issues
Old Dec 20, 2025 | 12:37 PM
Randy16's Avatar
Randy16
3rd Gear
headlight issues
I have a 1970 F250 with aftermarket LED headlights, and they are no longer working correctly. I have had them for close to 3 years and have never had a problem till now. They will flicker on and off or just stay off. If I hit my dash or a pothole hard enough, they come on for a second and then back off. The high beams work, but that is the only thing that is consistent. I just replaced the headlight switch, and they are still doing the same thing. Any help would be appreciated, thanks.
Old Dec 20, 2025 | 01:18 PM
Crop Duster's Avatar
Crop Duster
Dimmer switch ??
Old Dec 22, 2025 | 09:14 AM
fe390pc's Avatar
fe390pc
I think the headlights have failed. This is a common issue with LED headlights. So you use low beams mostly and that is why the high beams still work fine. It is just time to replace the headlights I am sorry to say.
Old Dec 22, 2025 | 10:29 AM
Randy16's Avatar
Randy16
3rd Gear
I hoping its just the dimer switch, just because its a lot cheaper to replace. I try that and hopefully it fixes the problem
Old Dec 27, 2025 | 08:44 PM
moto_hero's Avatar
moto_hero
Did you run an aftermarket harness for the lights or just use the original?
when I put them in my 68 they came with a aftermarket heavier harness. That was over 20 years ago so I don’t remember much.
definitely sounds like a short or failing part.
what headlights did you go with?
Old Dec 27, 2025 | 09:20 PM
Randy16's Avatar
Randy16
3rd Gear
The headlights I went with were just some random ones off of Amazon and no I dont remember them coming with a new harness, but for the moment I do believe it was a bad connection with the dimmer switch because i was messing with it amd they were kind of working so I waiting on a new one to arrive to see.
Jamey Eaton
22
Oct 12, 2021 01:49 AM
GarageFab
Feb 15, 2010 10:17 AM
horses4fun2
Dec 31, 2004 08:06 AM
Tattoo Matt
Oct 27, 2003 11:41 AM
