Headlight issue
Old Oct 6, 2021 | 08:51 PM
Jamey Eaton's Avatar
Jamey Eaton
Headlight issue
I’m driving my 66’ 2hrs every Monday morning to work out of town. I leave at 430am. While running my high beams, I have totally lost my headlights a time or two. Is this a sign that my high beam switch is going bad?
Old Oct 6, 2021 | 10:08 PM
lizardman1's Avatar
lizardman1
Or the headlight switch. Since you have had the core support replaced I would start there and check the wiring and the grounds at the headlight buckets.
ibuzzard's Avatar
ibuzzard
See A Man About A Horse
Replace the dimmer switch, they are inexpensive. If it still happens, change the headlight switch, also inexpensive. Do you have higher powered replacement headlights? They could be the problem. In that case, consider using a relay system to lower the current through the headlight switch
Old Oct 6, 2021 | 11:15 PM
Koolkat's Avatar
Koolkat
Most likely the headlamp switch as it should have a circuit breaker internally.
Old Oct 7, 2021 | 05:29 AM
jowilker's Avatar
jowilker
Dadgumit, That used to be an issue across the Ford truck board. We made some changes the wiring source and stopped it. I can not remember zackly what we did. We worked on the wiring changed the source of power as well as grounds. We ended up with brighter lights.
I wish my rememberier worked as well as my forgetter.
John
Old Oct 7, 2021 | 09:21 AM
jjriley97's Avatar
jjriley97
Mine was doing the same and it was the headlight switch. I did verify the grounds and tested the high beam switch first.
Old Oct 7, 2021 | 10:56 AM
ibuzzard's Avatar
ibuzzard
Even replacing the dimmer and headlight switches and improving the grounds - if you’re using much higher wattage headlights or lighting systems than stock, it can overload the circuit breaker in the headlight switch assembly, and cause it to trip. It would be more likely to do this at night using high beams.
Old Oct 7, 2021 | 03:35 PM
charliemccraney's Avatar
charliemccraney
Replace the headlight switch or install relays or try led headlights.
Old Oct 7, 2021 | 05:41 PM
Thunderkiss1965's Avatar
Thunderkiss1965
On the homepage of this FTE website, there is an article titled "Whiter whites, brighter brights". It explains the problem, Too much resistance in the headlight circuit causing the thermal breaker in the headlight switch to trip, and gives complete instructions to add relays to the system and eliminate the problem.
I was encountering the same issue and did the relay conversion last week. Fairly straightforward, It took me about three hours but I cleaned up a bunch of other wiring and added a fuse box at the same time. My lights are brighter and don't blink after being on for 30 minutes.
Old Oct 7, 2021 | 06:11 PM
ibuzzard's Avatar
ibuzzard
Originally Posted by jowilker
Dadgumit
Yeh, my Dad did that too, while his dentures were soaking.
Old Oct 7, 2021 | 07:36 PM
Jamey Eaton
Thanks for the info fellas!! To answer some of the questions, I have checked all of my grounds, I’m running sealed beam OEM headlights, low beams work flawlessly only issue is when I start running highs. One other question for you guys: Should I be able to dim my dash lights with my headlight switch or did they not do that in 66’?
I will look into replacing headlight switch and high beam switch 👍🏻
Old Oct 7, 2021 | 07:42 PM
ibuzzard's Avatar
ibuzzard
Yes, rotating the **** brightens/dims the dash-lights to some extent. If you do not have that function, it’s a strong clue that your headlight switch is toast.
Old Oct 7, 2021 | 07:46 PM
Jamey Eaton
It must be toast then 😎
Old Oct 7, 2021 | 08:33 PM
Thunderkiss1965
https://www.ford-trucks.com/article/...r_Brights.html
Here is the article. Just do it, it is THE fix. I( understand Toms Bronco Graveyard sells a harness with relays for this exact issue, if you are not comfortable with the wiring.
Dan TK65
Old Oct 7, 2021 | 09:40 PM
ibuzzard's Avatar
ibuzzard
Dan TK65
This is the best solution. Install an auxiliary fuse panel next to your battery. Anything new you want to add, like a high powered stereo, driving lights, high powered lighting systems, etc. - pull a new circuit from there.
I used the harness from Tom’s Broncos. It has the needed relays, and uses a separate fused circuit for each of the high and low beams. There is even a diode which, when left installed, allows you to run both beams simultaneously, or remove the diode for normal operation.You will never have a problem tripping that breaker in the headlight switch again, as current will no longer flow through it.
Put in a new headlight switch.
