proportioning valve
Old Dec 27, 2025 | 05:24 PM
1971F250 highboy's Avatar
1971F250 highboy
Trailering
proportioning valve
I have a 71 250 switched the front axle to a 79 dana 44 with disk breaks and am looking for a proportioning valve who has the best one that will fit the best bought 79 brake lines and put a booster on the truck.
Old Dec 27, 2025 | 05:44 PM
KULTULZ's Avatar
KULTULZ
Did you get the front axle from a donor vehicle or purchase separately?
The COMBINATION VALVE off the donor (rebuilt) should work.
Old Dec 27, 2025 | 05:54 PM
BobbyFord's Avatar
BobbyFord
Any aftermarket PV2 valve would work.
Old Dec 27, 2025 | 06:51 PM
1971F250 highboy
Trailering
I just got the frame and axles plus everything on the frame but am wanting to replace because not sure of condition of the valve
Old Dec 28, 2025 | 03:07 AM
KULTULZ's Avatar
KULTULZ
The PPV SECTION of the COMBINATION VALVE is vehicle specificat calibrated. If you don't have the correct valve from the vehicle you salvaged the brake system from, you maybe should consider using an ADJUSTABLE PPV.
These valves are usually rebuildable with available kits. If you want to keep the METERING VALVE and PRESSURE DIFFERENTIAL VALVE on the truck, the PPV section can be removed (internally) from the COMBINATION VALVE and an ADJ PPV plumbed in behind it.
Was the truck DRUM/DRUM before the FRONT DISC changeover? You will need a DISC/DRUM MC, preferably the one from the donor vehicle.
Henrys son
Apr 28, 2011 07:52 PM
kev78
Feb 6, 2011 04:30 PM
tfmech
Feb 3, 2011 05:07 PM
oldhalftons
Aug 18, 2004 02:40 PM
fatherdoug
Apr 14, 2002 11:58 PM
