headlight problem
Old Oct 23, 2003 | 03:13 PM
Tattoo Matt's Avatar
Tattoo Matt
headlight problem
when driving for usually about 30 min...my headlight will begin to go off ..on..off..on...then i will click my brights and it will stop...but my regular running lights are what come on...then i can click my high beams and they will come on..that seams to solve the problem for a short time ...any suggestions?
thanks...Tattoo Matt
Old Oct 23, 2003 | 04:03 PM
Torque1st's Avatar
Torque1st
Posting Legend
Bad circuit breaker in the headlight switch, -Replace the headlight switch.
Old Oct 23, 2003 | 04:20 PM
delliscoracing's Avatar
delliscoracing
It could be the dimmer switch.
Old Oct 25, 2003 | 02:08 PM
Tattoo Matt
where can i get a new headlight switch...don't want to get one from salvage...the same problem could happen..
Thanks tattoo matt
Old Oct 25, 2003 | 02:16 PM
TheWiz427's Avatar
TheWiz427
Your local auto parts place should have one.
Old Oct 25, 2003 | 05:24 PM
LxMan1's Avatar
LxMan1
There are real common. AutoZone even has them in stock.
Jimmy
Old Oct 25, 2003 | 06:48 PM
Tattoo Matt
sounds good Thanks guys!!
Old Oct 25, 2003 | 07:26 PM
Torque1st's Avatar
Torque1st
Posting Legend
The dimmer switch could be part of the problem also, you never know. The description of the problem was a little cloudy. Flashing is usually the CB... but not always
Old Oct 26, 2003 | 10:33 AM
plowpusher's Avatar
plowpusher
while you'er at may as well change the dimmer they onlt cost a few bucks and are easy to change just two 1/4 in headed sheet metal screws and one plug then go to the tech articeles and scope out the one for putting in headlight relays it's a good idea
Old Oct 26, 2003 | 10:43 PM
Torque1st's Avatar
Torque1st
Posting Legend
Remember to clean all of your contact points. Pull the contacts out of the housings and check for heating and corrosion where the wire is crimped. Solder any new connections. Coat all of the contact surfaces with silicone dielectric compound b4 assy.
Old Oct 27, 2003 | 11:41 AM
Truckmano5's Avatar
Truckmano5
Its the dimmer becuase mine did the exact same thing.
daddy172005
136
Aug 5, 2008 10:16 PM
Tattoo Matt
Dec 5, 2003 02:25 PM
Tattoo Matt
Nov 28, 2003 09:31 PM
Tattoo Matt
15
Oct 30, 2003 10:02 PM
Tattoo Matt
Oct 11, 2003 02:36 PM
