Issues Fueling up?
Old Dec 19, 2025 | 06:51 AM
Alaska Traveler's Avatar
Alaska Traveler
4wd Low
Issues Fueling up?
I’m going to be towing an 8.5’x24’ cargo trailer with home furnishings from Connecticut to Alaska. I’ve actually done this trip before with a smaller 6x12 cargo trailer, but I’ve never towed a trailer this big. ( I have towed boats this big though). Question is to anyone who tows this size, do you find it difficult to pull into gas stations to fuel up with such a large trailer. I’ll also note, it’s a F250 Gas not diesel, so I'm not sure the truck stop fueling areas for tractor trailers will accommodate me.
Old Dec 19, 2025 | 08:18 AM
SpencerPJ's Avatar
SpencerPJ
I never have issues with my travel trailer similar size. Seems city gas stations can get more cramped than gas stations off the hwy. Google maps satellite view can be useful. Good luck and safe travels!
Old Dec 19, 2025 | 08:21 AM
Alaska Traveler
4wd Low
Good idea using satellite maps! Thanks.
Old Dec 19, 2025 | 09:13 AM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
We pulled a 37ft 5th wheel to Alaska with a gas truck and never had a problem.
Denny
Old Dec 19, 2025 | 10:03 AM
WE3ZS's Avatar
WE3ZS
I pulled a 12K 41’ TT behind a V-10 Excursion for 80K miles, so made lots of gas stops. As mentioned above the big stations just off the Interstates should allow for easy fill ups, sometimes you will need to be patient and wait for the pump that is the easiest to open up. And no, the truck stop big rig lanes do not have gas pumps, only diesel.
Old Dec 19, 2025 | 10:09 AM
seventyseven250's Avatar
seventyseven250
I have found sattelite photos of the fuel stops can be really helpful to figure out both if your'll fit, but also if there's a "bail out" area for you to get turned around if you were wrong. If you plan your fuel stops for places with restaurants, you can send your family inside while you fuel and get a few minutes of peace and quiet.
Old Dec 19, 2025 | 11:41 AM
99powerstrokedF250's Avatar
99powerstrokedF250
I'll echo what the guys above said, stop at bigger stations in smaller cities/towns (not a big city - those are more often going to be TIGHT), and you shouldn't have any problems. Truck stops usually have a gasoline side separate from the diesel lanes, and they're usually pretty wide open as well.
Old Dec 19, 2025 | 01:06 PM
Phillbo's Avatar
Phillbo
You'll be fine.I tow a 30' travel trailer and while my truck is diesel I rarely use the trucker lanes unless the retail side is going to be a nightmare (usually due to gassers taking up all the diesel pumps).
as stated just spent a couple moments before you start your day scoping out your fuel stops on da google.....
One thing that helps me is I've upgraded to a 60 gallon fuel tank so I have well over 800 miles before I have to get fuel which allows me to skip iffy situations but I also rarely take advantage and stop for fuel when half full to stretch my legs and if traveling with dog and wife, give them a chance to go pee and get snacks
Old Dec 19, 2025 | 01:11 PM
AppleFordParts's Avatar
AppleFordParts
SPONSOR
When we pull the camper my wife navigates us to good fuel stops. She'll go as far as looking them up on MAPS so she can see how the pumps are oriented, really makes fuel stops less stressful.
-Steve
__________________
spowell@appleautos.com 1-800-328-9552 dfairbanks@appleautos.com
Old Dec 19, 2025 | 03:20 PM
Alaska Traveler
4wd Low
Good Info, Thanks everyone.
Old Dec 19, 2025 | 06:35 PM
WE3ZS's Avatar
WE3ZS
Do you not make use of the Open Roads or Mudflap’s diesel fuel discount programs at truck stop fuel pumps? Those discounts really add up over time!
Old Dec 20, 2025 | 09:45 AM
kshoop1958's Avatar
kshoop1958
You'll be fine with the above advice, but I'll add that try to use the pumps on the end when I'm towing my 31' fifth wheel. As far as price goes I lean towards convenience and low stress, so I try to use Interstate truck stops. But, the Love's app will get you $0.10 off per gallon, and another $0.03 per gallon off if you have a AAA membership and connect it to the app. That $0.13 per gallon discount makes my local Love's cheaper than my nearest Costco sometimes. Pilot / Flying J also offers $0.10 off per gallon with their app.
Safe travels, and enjoy the journey!
Old Dec 20, 2025 | 12:25 PM
Phillbo's Avatar
Phillbo
I use Open Roads but the problem is in the fact I HATE traveling on the interstate and always try to take the back roads so Truck Stops don't come into play much on our travels. If I know I'll have to get on one (had to get on I 15 south of Provo on our last trip) I'll plan for a full fill up at a truck stop and use the card.
I travel to relax and enjoy the views and smaller towns along the route. Try to avoid anything with an "I" in front of it.
Old Dec 20, 2025 | 06:50 PM
Midwest87's Avatar
Midwest87
At 4 AM, youll have plenty of room to pull in and refuel.
Old Dec 20, 2025 | 08:27 PM
cougrrcj's Avatar
cougrrcj
I get the 'backroads scenery' bit. My parents did the same when they were full-time RVers - much more scenic but sometimes nerve-wracking! Interstates have a maximum grade (angle) and that State highways do not. There are some steep roadways out that way in the Rockies/Cascades!!!! Same for road shoulders. Interstates have wide shoulders, backroads do not! My Old Man called many such twisty/skinny mountain backroads as 'First-Class Yeech!'
Also, make sure you are hitched correctly. Load distribution inside the bigger trailer is critical to stability. A good anti-sway control might help if windy, because that trailer has a lot of 'sail area'...
