Tune up parts for 330
Need help im trying to find a rotor and cap for it but can't find anything about it the vin is F60DTA44759 any help would be much appreciated 580 775 1404 is my phone number il talk to anyone who can help
Welcome to FTE. I moved you here and away from that other thread. This is the forum for F600 and similar/larger trucks.
Good news for your cap and rotor: Almost ALL Ford V8s from 1958 to 1973 use the SAME cap, rotor, and points. (High Performance dual point setups are one exception)
So, just ask for a cap and rotor from a V8 anything--early '70s pickup is probably easiest.
F60 = F600 gas, 4x2
D = 330 2V HD FT gas V8 (Heavy Duty--that will matter for some parts)
R = San Jose Assembly Plant
A44659 = 1967 numerical series, November 1966 production
194 = 194 inch wheelbase
M = White
F602 = F600 gas, 4x2, 20,000 lbs GVWR
481
4 = Medium Beige Vinyl
81 = Cab and chassis vehicle, possibly Standard Cab
A = New Process model 435 four speed transmission
F7B
F7 = Eaton model 13802 two speed rear axle, 15,000 lbs capacity, 5.83 / 8.11 ratios
B = Ford 5,500 lb capacity front axle
20000 = 20,000 lbs GVWR
164 3800 = 164 Certified Net HP @ 3800 RPM
72 = San Jose District Sales Office
No special order.
Check for widowmaker wheels:
https://www.ford-trucks.com/forums/8...l#post19892682
Eaton videos on the two speed if you are not familiar:
https://www.ford-trucks.com/forums/1...ml#post9565523
F60 = F600 gas, 4x2
M = White
481
F7B
No special order.
adgjqetuo
Sep 2, 2021 10:24 AM
Damen69
Nov 19, 2016 10:28 AM
