Help on correct eec-4
Old Aug 7, 2024 | 10:57 AM
rrsteamer's Avatar
rrsteamer
4th Gear
Need correct eec-4 part number for vin 1.FTEF.14Y7HNB.
03277? Any thoughts?
Old Aug 7, 2024 | 01:19 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Do you have the calibration code that is on the driver’s side B pillar? What is wrong with the computer that is currently in the truck?
Old Aug 7, 2024 | 06:56 PM
rrsteamer's Avatar
rrsteamer
4th Gear
Calibration number
Sorry, there is no calibration number to be found. I am not sure that it is a computer problem. But have been unable to correct other problems. However, letter on computer is not complete as the first letter is either F or E. Am just trying to get the correct information as am suspect this maybe a replacement as this truck has gone thru at least 4 owners.
Have done the usual change out of usual parts but unable to get computer to fire up to get any codes (koeo). Eng will turn over but unable to trace no spark. Dist & mod changed out. Just out of hospital about 5 days so this problem will probably stretch out for a while. Thanks for the response.
Old Aug 7, 2024 | 07:44 PM
My4Fordtrucks
According to the VIN it is a 1987 with a 300 engine?
Old Aug 8, 2024 | 07:19 AM
rrsteamer's Avatar
rrsteamer
4th Gear
Correct 4.9, m/t 4x4
Old Aug 8, 2024 | 09:41 AM
rla2005's Avatar
rla2005
It would be helpful to post the calibration code usually attached to the driver side b-pillar.
Example:
In the example above the pertinent numbers are 8-53E-R10
Gigglr
Nov 19, 2016 04:12 PM
zombiefied 247
Oct 8, 2014 04:42 PM
Ohydro91
May 22, 2011 09:36 PM
skidooman
Jun 11, 2009 09:57 PM
brianlr77
1966 - 1977 Early Broncos
Nov 24, 2003 12:07 PM
